Old 10-20-2023, 11:33 PM   #1
Loganp98
Drives: White Subaru brz
Hey guys I could use help with a code
My 15 brz is having an issue with code P2109 on. I have already tried a test throttle body and PCM. Neither fixed the issues. I have tried using my OFT to clear the code and disconnecting the battery. Neither will clear the code out. The engine revs to 1500 rpm and I have no throttle response. Thanks for any help.
Loganp98 is offline   Reply With Quote
Old 10-21-2023, 10:37 AM   #2
Spairo
Drives: 2013 FR-S 6 spd in Halo
P2109 Throttle/Pedal Position Sensor A Minimum Stop Performance
"Sensor A" means that the DTC is referring to a particular sensor, which in this case could be the TPS or the pedal position sensor.
Since it sounds like you have a source for donar parts, I would try swapping the PPS next.
Otherwise, you need to get your hands on wiring diagrams/pinouts for the TPS and the PPS and start checking resistance through them.
Go fast, take chances.
Spairo is offline   Reply With Quote
Old 10-30-2023, 06:07 PM   #3
Loganp98
Hey there. I tried another pedal with no luck. Any other ideas?
Hey guys I need help with a code Loganp98 Issues | Warranty | Recalls / TSB 7 11-01-2023 09:07 AM
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 05:52 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 09:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 11:19 PM
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 07:56 PM
