Old 06-19-2023, 01:39 AM   #1
banzai-88
Drives: 2015 FRS
Starting problem, no resolutions in 8 months
Hey y’all, got a brain bender for you
Here’s the breakdown, my gf’s FRS (2015 AT) has a starting issue and has for 8 months, the car got tuned on ECUTek by delicious tuning and they’ve been extremely helpful but still no fix at all. Mod lists goes as follows, HKS drop in filter, custom catless headers, no name exhaust (came on car), Cusco catch can, rally suspension, rally wheels, etc. nothing done to engine other than filter and exhaust.
So here’s the problem, the car runs great, like an absolute dream, but it does not start the first time on hot start. It starts every single time on cold start, except when it’s hot outside. On hot start and when it’s warm outside, it can take 4-10 times to get the car running. It idles for a couple seconds, really roughly, then it turns off.
Data logging wise, the injectors just turn off, they go to zero on the data table right before the car dies.
You can unplug the MAF sensor and put the car in limp mode and the car will start everytime, no matter hot or cold.
We really can not figure out what it is, there’s been no luck at getting closer with a solution and she’s been dealing with it since November, it’s kinda just become something she’s lived with. However getting into the summer months, it’s getting worse and taking significantly longer to get the car running when she wants to drive it.
Any ideas on what we should do, really ready to figure this one out, ECUTek had no idea what the issue could be. No hate or slander towards delicious at all, they have been absolutely amazing in terms of support
banzai-88 is offline   Reply With Quote
The Following User Says Thank You to banzai-88 For This Useful Post:
humfrz (06-22-2023)
Old 06-22-2023, 02:43 AM   #2
Hell, that's waay over my pay grade - however, I'd start by replacing the MAF sensor.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
alphasaur (06-22-2023), Clipdat (06-23-2023), whataboutbob (06-23-2023)
Old 06-22-2023, 02:58 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Has the main harness ever been disconnected? Sounds like a wiring issue you’ll either need to chase down with a multimeter or just Chuck money at.
ineedyourdiddly
Old 06-22-2023, 11:36 PM   #4
Grady
Grady's Avatar
Since you have not modified your engine have you reloaded stock tune? This would be a good way to eliminate tune/software issues.
The Following 2 Users Say Thank You to Grady For This Useful Post:
Old 06-23-2023, 12:37 AM   #5
whataboutbob
AutoX-10/10ths every run
I had a damaged o-ring on my MAF and the car was intermittently having idle issues. Replaced the (original) MAF and the issues went away.
+1 on getting a new MAF.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
fuel injectors, no start, rough idle
Help Please! starting problem Pureluck868 BRZ First-Gen (2012+) — General Topics 1 10-13-2021 10:01 PM
Intermittent starting problem LS1M Software Tuning 4 06-12-2017 03:03 AM
BRZ limited odd starting problem. armstrom Issues | Warranty | Recalls / TSB 19 04-06-2016 11:21 PM
Del Sol starting problem Ashikabi Other Vehicles & General Automotive Discussions 5 03-22-2016 08:24 PM
Starting problem ricerocket93 Issues | Warranty | Recalls / TSB 5 09-06-2014 04:15 PM
