Old 09-14-2021, 10:48 AM   #1
Akrochik
Drives: Golf TDI for now
Suspension bouncing on long right hander
My car was doing something odd on track in my last session. There's a long med/high speed right hander with a lot of camber and many times in that corner my car did a sort of rhythmic bouning when I was around 33% throttle. This in the second half of the lightbulb at NJMP lightning, for those familiar.
Is this porpoising? Anything I can do to address? Thanks!
2013 FRS
Tein Flex Z coilovers set to about 66% of the way to full firm
1" lower than stock
Stage 2 tune and bolt ons
Akrochik is offline   Reply With Quote
Old 09-14-2021, 03:01 PM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
Could it be a blown damper?
Old 09-14-2021, 03:12 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
+1 play with the damper knobs and see if you can find an improvement.
Assuming there's nothing bound up or worn out on the suspension.
ineedyourdiddly
Old 09-14-2021, 03:15 PM   #4
CSG Mike
CSG Mike's Avatar
Do you have a datalog?
Old 09-14-2021, 04:18 PM   #5
Akrochik
Only what's in TrackAddict but I do have onboard video where you can sort of see the bouncing.
Old 09-14-2021, 04:21 PM   #6
Akrochik
Coils are about 9 months old and the ride is pretty compliant in general so I'd be surprised if a damper has failed already. But I'll take a look.
I do get a front suspension clunk when reversing out of the driveway with the wheel turned after the car sits for a while but it's been doing that for a long time. I'll check if anything has any play.
The Following User Says Thank You to Akrochik For This Useful Post:
alphasaur (09-15-2021)
Old 09-14-2021, 04:23 PM   #7
CSG Mike
CSG Mike's Avatar
I specifically need a datalog to help you. Otherwise, we're just guessing.
Any clunking is not normal.
norcalpb (09-14-2021)
Old 09-14-2021, 06:42 PM   #8
norcalpb
norcalpb's Avatar
How are your axles looking? Any play in the CV joints when you shake the axle from the middle of the shaft?
Old 09-15-2021, 10:30 AM   #9
femaledog
Drives: 2017 BRZ Perf. Pkg.
Would you characterize the bouncing as more of "left to right" or "front to back"?
femaledog is offline   Reply With Quote
Old 04-03-2023, 01:16 PM   #10
Akrochik
Thanks to all that tried to help. Going full firm on the dampers fixed it. The clunk was fixed when I greased the end link fitting
strat61caster (04-03-2023)
Bouncing on high speed right-hander on track Akrochik Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 09-20-2021 02:45 PM
Rev bouncing in first? jc7993 BRZ First-Gen (2012+) — General Topics 18 04-10-2019 12:44 PM
Bouncing revs Ondreiko Engine, Exhaust, Transmission 40 08-11-2015 06:10 AM
FS: Long Island... Stock Suspension less than 200 miles whitefrs Brakes, Suspension, Chassis 25 04-04-2014 03:39 PM
Long Island RCE Suspension Starter Kit DIY Foobar NY / NJ / CT / PA 15 12-14-2012 01:47 PM
