Old 01-25-2023, 04:59 PM   #1
julzbrz
julzbrz's Avatar
Drives: ‘14 brz
Coolant Leak
Hey guys, back again with more problems😩 So I’m having a coolant leak and it seems to be one of the lines or pipes that eventually leads down to the AT cooler. I’d rather replace it myself so I’m just wondering if anybody knows what the part is called or has the part number? I attached a pic with a circle indicating where the hole is. Any info or tips would be greatly appreciated
julzbrz is offline   Reply With Quote
Old 01-25-2023, 05:26 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The best idea in this position (When you don't know what a part is) is to try googling things related to it. Try Googling " BRZ AT coolant hose" or "BRZ AT Transmission cooling system" and go through a bunch of the imaging results until you find something that resembles the part you're looking to replace. This strategy works for basically anything as long as you provide the model of the car and can describe what it is with a couple basic words common in the automotive world.
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
soundman98 (01-26-2023), x808drifter (01-26-2023)
Old 01-25-2023, 07:18 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
https://parts.subaru.com/a/Subaru_20...10-150-17.html
HELP! Coolant Leak in driver side cabin. pakunodafie Engine, Exhaust, Transmission 2 09-13-2022 09:58 AM
Coolant Leak from under AC Compressor Swassofrass Issues | Warranty | Recalls / TSB 12 06-26-2020 12:16 PM
Coolant leak, radiator replacement James Russels Engine, Exhaust, Transmission 6 09-08-2019 04:41 AM
Possible coolant leak RedNWhite Issues | Warranty | Recalls / TSB 19 09-25-2016 10:35 PM
coolant leak or burned rubber smell Saf Issues | Warranty | Recalls / TSB 7 02-27-2014 02:33 AM
