| BRZ Second-Gen (2022+) General Topics General topics for the second-gen BRZ |
Drives: 2022 BRZ coming
Aircon effectiveness
Hi all! I would like to hear your experiences: Do you find the Aircon to be a little on the weak side? My experience with modern and modern-ish cars is that they get freezing cold when the Aircon is cranked up (beyond the midway setting point), so usually I'm at setting 1 or 2 (out of 4) for extended driving. But with the (2022) BRZ I find that I have to crank up to midway or higher on hot days in order to not be uncomfortably warm. I would like to hear other people's experience so I can figure out of if it's a common issue. Thanks!
#2 |
Drives: 2022 BRZ
I set mine to full auto and just adjust the temp. The AC for me has been really good and usually keep it 71-74 and I live in FL where we've been upper 90's low 100's daily. No issues with AC keeping up.
#3 |
Drives: Subaru BRZ
Cold as balls on mine.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Grosbard (07-13-2022) |
#4 |
No issues here.
On my 2013 the AC was weak and I needed to add some coolant to it. |
| The Following User Says Thank You to jvincent For This Useful Post: | Grosbard (07-13-2022) |
#5 |
Drives: 22 BRZ
In Texas where we've already had 30+ days over 100 this year - blows super cold and has no issue keeping up. I just leave it on automatic mode at the temp I like (71-72). I do have good quality ceramic tint all around.
| The Following User Says Thank You to otter For This Useful Post: | Grosbard (07-13-2022) |
#6 |
Drives: GR86 Premium AT Trueno Blue
it's incredible on mine... thing gets down to set temp FAST
| The Following User Says Thank You to DylanJZA For This Useful Post: | Grosbard (07-13-2022) |
#8 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Drivers side was blowing warm air last month, blowing 42 degrees now after adding a 1/2 can of freon.
| The Following User Says Thank You to BirdTRD For This Useful Post: | Grosbard (07-13-2022) |
#9 |
Drives: 2022 BRZ WRB
Did you press the "Max A/C" button? I made that mistake too already lol, didn't realize there was 2 different A/C modes.
| The Following User Says Thank You to Midnightsky For This Useful Post: | Grosbard (07-13-2022) |
#10 |
Drives: '04 STi, '12 Mazda 3 Hatch
| The Following 2 Users Say Thank You to Lelandjt For This Useful Post: | Grosbard (07-13-2022), Midnightsky (07-15-2022) |
#11 | |
Drives: 23 BRZ
I echo the recommendations to install ceramic tint. It blocks heat very well, so the A/C system doesn't have to work as hard. In the heat of the summer, I'd rather get into a black car with ceramic tint than a white car with no ceramic tint, and I've owned multiples of both of those combos. |
| The Following User Says Thank You to mike2100 For This Useful Post: | Grosbard (07-13-2022) |
#12 |
Drives: 13 AT FRS
The few times I used it and thought the same thing. Those were days that were 90+ with a very high level of humidity. I dont think anything is defective though.
| The Following User Says Thank You to Ogt For This Useful Post: | Grosbard (07-13-2022) |
#13 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Like the others have said, my A/C performs like a champ. In fact it is so cold, I've had to raise the temp on the Auto settings because it is too cold and I'm trying to find the best way to aim the vents so it doesn't freeze me out of the car.
On 100F days with humidity driving the heat index north of 110, I've been quite comfortable in the car. This car seems to do a good job of both the volume of air it moves and the temperature of the air itself. My last two cars have struggled with at least one of those two variables. In my MK6 GTI, the air temp was good, but even on high the vents moved very little air. My F30 BMW 4 series moved a lot of air, but it never got as cool as I'd like. The BMW also had the extra bennefit of the condenser freezing/icing up in high humidity when run for long periods of time. Lovely design flaw.... |
| The Following User Says Thank You to Desertnate For This Useful Post: | Grosbard (07-13-2022) |
#14 |
I remember reading a similar thread a few years ago. My '13 is a bit on the weak side. That thread got me to thinking that the factory may have skimped on the refrigerant to save some money. It hasn't bothered me enough to go through the trouble of tweaking the charge. Without a sight glass, we need to follow a detailed procedure to get it just right.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Grosbard (07-13-2022) |
| Aircon blowing cold on one side | Kris86 | Issues | Warranty | Recalls / TSB | 9 | 05-12-2020 01:36 PM |
| Cost Effectiveness of Modifying Your Car | Tristor | BRZ First-Gen (2012+) General Topics | 12 | 09-23-2018 12:22 AM |
| Dual Zone AirCon Operation | Esseff | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 05-01-2017 07:05 PM |
| Effectiveness of a Lightweight pulley | DrifterX | Engine, Exhaust, Transmission | 94 | 12-11-2016 02:10 AM |
| Swap Aircon HVAC controls from BRZ/GTS to FRS/GT | MudithJ | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-04-2016 11:13 AM |
