Drives: 2017 BRZ w/PP
boostedboiz bought a frs to kswap
excited for this |
#2 |
Drives: 2013 frs base
Single piece aluminum driveshaft? I still have nightmares about critical speed and pinion angles.
#3 |
Rust bucket enthusiast
Hell yeah, these are my favorite people to watch, when they're not doing boats/at shit
#4 |
#5 |
I hope they do too. They are an inspiration
#7 | |
Drives: Crapcan
DSS has already came out and said critical speed is the issue in the one piece AL shaft. Carbon and steel have higher CS so it’s not really a problem with those shafts. I talked with DSS about it after blsfrs had his issue.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (06-05-2022), soundman98 (06-05-2022) |
#8 |
Drives: JRSC BRZ SOLD
Ok, has anyone tried aligning the diff to the new angle? Or shimming the transmission as well?
#9 | |
Drives: Crapcan
There’s a thread on it somewhere a few guys were working on it. The pinion angles on my car were not bad without shimming anything but my subframe is a little higher then stock. If I find it I’ll link it.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | PulsarBeeerz (06-05-2022) |
#10 | |
| The Following User Says Thank You to blsfrs For This Useful Post: | NoHaveMSG (06-06-2022) |
#11 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (06-06-2022) |
#12 |
This is from IAG for a 2008-14 STI.
The Driveshaft Shop 1-piece 6061-T6 3" aluminum shaft that is approximately 1/2 the weight of the factory 2-piece driveshaft. The 1-piece aluminum shaft features larger, replaceable, greaseable u-joints and can handle about 650WHP and 155 MPH. By removing the factory 2-piece shaft and installing a single shaft the car will feel more responsive due to the lighter weight of the shaft and also the fact that the hanger bearing is not moving up and down during acceleration. Please Note: This driveshaft is rated to 650WHP and a top speed of 155MPH and is not recommended for use above this speed. This aluminum driveshaft is 3" diameter and your vehicle may require some minor modifications to the driveshaft tunnel in order to ensure proper fitment. Make sure there is at least 3/4" clearance around the driveshaft before use, and that the differential bushings are not worn as this can cause damage to the driveshaft. Damage caused by improper fitment will not be covered under warranty. I'm guessing the STI driveshaft is much shorter that ours. |
#13 |
Drives: None
I didn't bother measuring when I had the two driveshafts side by side, but the K series one is a few inches shorter.
I intend to have my stock driveshaft shortened to match the K series one at some point over the next few months.
| The Following User Says Thank You to RedReplicant For This Useful Post: | blsfrs (06-08-2022) |
#14 |
their last video said they are going to turbo or SC it but they arent sure year. I cant wait to watch the carnage
| The Following User Says Thank You to Breadman For This Useful Post: | Tcoat (06-09-2022) |
| I bought and totaled a BRZ. Then I bought another. | unhappymeal | BRZ First-Gen (2012+) — General Topics | 51 | 06-07-2017 08:54 AM |
| FI Guys: Were you more excited when you bought your car, or when you bought boost? | husker741 | Forced Induction | 28 | 02-25-2014 04:57 PM |
| just bought my FR-s! | rosgonz | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 07-16-2013 12:29 AM |
| Best store bought or online bought wax | ThatManAnt | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 16 | 03-12-2013 10:32 PM |
| Just bought some... | markmatley | Hawaii | 0 | 11-27-2012 04:44 PM |
