Old 03-26-2022, 11:24 PM   #1
Kulebrero1
Drives: Gr86
$5K for track build
About to pick up a GR86. Will use it mostly for track duty…must be street legal so I can drive it to/from the track.
If you had $5K for upgrades, what would you do?
Kulebrero1 is offline   Reply With Quote
Old 03-26-2022, 11:28 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
what is your track experience?
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
soundman98 (03-27-2022)
Old 03-27-2022, 12:16 AM   #3
ozafar
Drives: 2015 Scion FRS Release Series 1.0
18x8.5 +40 rims with tw200 tires…2000
Rcr ss1 coilovers…1600
Proper brake pads and fluid…400
The remaining 1k up to you.
ozafar is offline   Reply With Quote
Old 03-27-2022, 01:43 AM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Have you factored in recurring and consumable costs?
EndlessAzure is offline   Reply With Quote
Old 03-27-2022, 05:27 AM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Camber plates, camber bolts, rear lca, alignment -3 and -2 degrees camber F/R to start: $1k-$1.5k, car will probably want more camber but you’ll figure it out in time.
Use up the factory ps4s, pick next tires as desired $1k give or take.
Brake pads $500
Brake fluid $50
Real oil cooler $750
Use the rest on gas.
ineedyourdiddly
Icecreamtruk (03-28-2022)
Old 03-27-2022, 08:32 AM   #6
SCFD
If I was to completely start over again, this is what I'd do:
  • Driving school(s)
  • Simpson Hybrid Sport + compatible helmet
  • Track pads + fluid
  • Oil cooler
  • Front camber plates / rear camber arm
  • Action cams (in-car + external) + data logging
SCFD is offline   Reply With Quote
The Following 6 Users Say Thank You to SCFD For This Useful Post:
BigTuna (03-27-2022), Icecreamtruk (03-28-2022), Re_Invention (04-01-2022), smg1138 (03-29-2022), strat61caster (03-27-2022), treedodger (03-30-2022)
Old 03-27-2022, 10:31 AM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
the BEST first question.
also, $5k what? $5k per track day? $5k per month? $5k per year? $5k all-in(and no one is ever all-done paying for track stuff)?
CSG Mike (03-28-2022)
Old 03-27-2022, 11:07 AM   #8
Kulebrero1
Drives: Gr86
~20 track days in a modified Miata.
Already have a helmet, Hans, camera, data logger, and tools.
I have $5K for initial upgrades.
I’m seeing a lot of recommendations to start with an oil cooler. How serious are the overheating problems on track? Besides the oil cooler, would hood vents help?
- oil cooler
- wheels/tires
- coilovers
- camber plates / alignment
- brake pads, fluid, lines
- sway bars
Old 03-27-2022, 11:15 AM   #9
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
If the suspension is in decent shape, you might run it stock for a while. Spend the extra $1k on a header and a tune. In Va? Are you going to run Summit Point and VIR?
Old 03-27-2022, 11:41 AM   #10
TommyW
TommyW's Avatar
- oil cooler
- wheels/tires
- coilovers
- sway bars
Those items are pretty much the go to. The oil cooler will get you mixed responses on this forum. Personally, I’m a fan of them. The new gen 2 cars have one however apparently it’s just not that efficient. The hood vents are more about eliminating lift at the front.
Old 03-27-2022, 03:46 PM   #11
jflogerzi
jflogerzi's Avatar
Nothing but Brake Fluid, pads, and camber adjustments. They are really good stock already.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
blsfrs (03-27-2022)
Old 03-27-2022, 04:19 PM   #12
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
So, the response depends on how many days per year you want to do and what your goals are. If you're doing fewer than 10 days per year and are just looking for some fun trackdays, $2k for a set of RS4's and some wheels (17s to keep the costs down) then some camber plates/bolts for the front and some good pads. Keep the rest to do more events.
If you're looking to do more events then I'd get the AP Racing sprint kit, the pads are cheaper and last longer plus you'll never have to worry about brakes. I'm also in the pro-oil cooler camp, I ran one on my 2014 and only had to tighten the connectors once over 6 years with 30 or more days per year. You'll probably also want some coilovers, I'd recommend doing it right the first time so you don't feel like doing it a second time. Unfortunately, wheels and tires, AP brakes, oil cooler, and suspension is going to run about $7k.
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
blsfrs (03-27-2022)
Old 03-27-2022, 10:45 PM   #13
Kulebrero1
Drives: Gr86
I’ve been to all three tracks at Summit Point, Dominion, Pitt Race, and Lightning at NJMSP. Haven’t done VIR, yet. It’s on the bucket list.
Any other good ones near VA?
Old 03-27-2022, 10:48 PM   #14
Kulebrero1
Drives: Gr86
The AP Racing Sprint Kit is $2,300. I’m all about the brakes, but that’s a lot.
Agree on the coilovers. Will go with a good set the first time.
Mr. Frs Trd track build Mr.Frs Member's Car Journals 24 06-20-2018 07:20 PM
dp1 track build (NY) dp1 NY / NJ / CT / PA 114 07-19-2017 02:47 PM
What's your Track Build? neroman98 BRZ First-Gen (2012+) — General Topics 4 08-06-2015 05:16 PM
FRS Track Build smoltz Tracking / Autocross / HPDE / Drifting 27 07-08-2015 10:17 AM
mrharry 86 Track Build mrharry Member's Car Journals 5 08-10-2014 02:44 PM
