Old 03-29-2022, 05:23 PM   #1
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
Highervalve lift with shims
Has anyone ever tried to get a little more valve lift by adding small shims under the post that tbe rocker rests on? It seems reasonable that raising the resting place of the rocker would translate into higher lift. Obviously, thia would need to be a small amount and still keep valve train geometry in good shape. Lmk
Rabrooks is offline   Reply With Quote
Old 03-29-2022, 05:35 PM   #2
Tokay444
lol
The Following User Says Thank You to Tokay444 For This Useful Post:
NoHaveMSG (03-30-2022)
Old 03-29-2022, 10:58 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
how does moving the fulcrum up alter how much lift the cam shaft provides?
Old 03-30-2022, 08:33 AM   #4
Tokay444
He's not talking about moving the fulcrum.
What he is talking about is removing lash.
Op, if you shim them enough that they're opened all the time, that will reduce pumping losses.
soundman98 (03-30-2022)
Old 03-30-2022, 11:13 AM   #5
Lantanafrs2
Drives: 2013 frs red
Nice backfires too
Lantanafrs2 is offline   Reply With Quote
Old 03-30-2022, 11:26 AM   #6
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
The valves wouldnt close all the way then...
They also make bigger cams for just this reason
The Following 2 Users Say Thank You to Breadman For This Useful Post:
DocWalt (03-30-2022), Tcoat (03-30-2022)
Old 03-30-2022, 12:54 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Lift would still be the same, as pointed out already, you are just changing the lash.
Old 03-30-2022, 02:01 PM   #8
Tokay444
I say go for it because, “you don’t know until you know.”
Jdmjunkie (03-30-2022)
Old 03-30-2022, 08:49 PM   #9
Rabrooks
Rabrooks's Avatar
I thought the rocker ratio might provide a small advantage after altering the geometry. Oh well. A passing thought
Old 03-30-2022, 09:10 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Realizing now I miss read the intent of what you where trying to do. Still wouldn't do it as I have had a rocker arm eject on an FA20 before. Raising the pivot seems like it would make it more unstable to me. It is not as simple as changing the rocker ratio on a pushrod motor.
Old 03-31-2022, 12:59 AM   #11
makinen
makinen's Avatar
Drives: Toyota 86
Question
Will raising the pivot point (red arrows) result in higher lift? The shim at the top of valve stem should changed accordingly.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 03-31-2022, 12:33 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't think so. Since the fulcrum is on the end the length of the arm is the same.
Differential shims source gpvecchi Engine, Exhaust, Transmission 7 05-16-2019 11:47 PM
Brake pad shims Newtothegrounds Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 04-14-2019 06:43 PM
Rear brake pad shims Tacticalpanda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-16-2018 03:58 PM
Shims for mfactory 4.67 fd Imranman Engine, Exhaust, Transmission 2 09-29-2017 10:26 AM
Tial Q shims ft86me Forced Induction 0 07-21-2017 02:58 PM
