Highervalve lift with shims
Has anyone ever tried to get a little more valve lift by adding small shims under the post that tbe rocker rests on? It seems reasonable that raising the resting place of the rocker would translate into higher lift. Obviously, thia would need to be a small amount and still keep valve train geometry in good shape. Lmk
lol
how does moving the fulcrum up alter how much lift the cam shaft provides?
What he is talking about is removing lash. Op, if you shim them enough that they're opened all the time, that will reduce pumping losses. |
Nice backfires too
The valves wouldnt close all the way then...
They also make bigger cams for just this reason |
Lift would still be the same, as pointed out already, you are just changing the lash.
I say go for it because, “you don’t know until you know.”
I thought the rocker ratio might provide a small advantage after altering the geometry. Oh well. A passing thought
Attachment 210695
Will raising the pivot point (red arrows) result in higher lift? The shim at the top of valve stem should changed accordingly. |
| All times are GMT -4. The time now is 06:49 AM. |
User Alert System provided by
