Old 01-20-2022, 01:02 PM   #1
FcWill
FcWill's Avatar
Drives: 2014 Scion FR-S Monogram
wheels/tires and coilovers
Hey guys, Im new to the car world. I recently got a 2014 FRS and I want to change the wheels from the stock ones (215/45R17, 17x7+48) to some aftermarket ones (245/35R18, 18x8+38). the thing is, i dont want the wheels to rub because my suspension is still stock, so im thinking about going on coilovers. the thing with that is that i read somewhere online that the cv joints on this car are weak, so i would need a diff/subframe riser if im going on coils. is that true? I want to keep the stock height, maybe lower it by .25-.5 of an inch. would i need a diff riser so that the cv joint doesnt break?
FcWill is offline   Reply With Quote
Old 01-20-2022, 01:08 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Why 18's? They are more expensive, heavier, and tires are more expensive.
There is an entire section of the forum with tire/wheel setups with pictures. I recommend looking there. People are getting away with 245's on stock struts.
The stock CV's are not an issue unless you are running stupid low, and even then it is not the issue people make it.
Spuds (01-20-2022)
Old 01-20-2022, 01:15 PM   #3
StraightOuttaCanadaEh
Wes
for .025 to 0.5 of an inch I don't think you need coilovers, I think lowering springs will do. Having said that, I do have 18 x 9.5 wheels with 255 or 265 tires and I am on coilovers and haven't needed any diff risers after 5 years...
Instagram: @gt86ws
Old 01-20-2022, 04:11 PM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
^^ what he said. And I'll make it even easier.
https://www.ft86club.com/forums/forumdisplay.php?f=24
Old 01-20-2022, 05:04 PM   #5
BRZpat
Drives: BRZ Limited, V10+ R8, Macan S
Because they look nicer looking on the car than 17's lol. Why do anything aesthetic on this car? Because it looks better!
BRZpat is offline   Reply With Quote
Old 01-20-2022, 05:10 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If that is your reasoning that is fine, a lot of people don't understand the negatives which is why it gets asked.
Old 01-20-2022, 07:37 PM   #7
ICauseCalamity
Drives: Totaled 2013 Toyota Corolla
If you aren't planning too much of a drop you don't need to worry about diff raisers, this would be more of a track oriented modification or extreme low applications. I'm on Fortune Auto 500 coilovers with around a 2" drop and I've been pretty good. I'm also at around 400whp so any issues present would've made themselves more apparent. Check fitmentindustries' gallery out to get an idea of what wheels and tires would look like on our platform.
ICauseCalamity is offline   Reply With Quote
Old 01-20-2022, 08:39 PM   #8
Grady
Grady's Avatar
Those wheels and tires will make you car slower also. But if looks is all you are after then have fun.
Old 01-20-2022, 10:17 PM   #9
BRZpat
The car is already incredibly slow. lol nothing short of turbo will make it reasonable.
Old 01-22-2022, 11:01 PM   #10
FcWill
FcWill's Avatar
if i were to go on lowering springs, will i be able to use the stock struts or would i have to buy new ones?
Old 01-22-2022, 11:47 PM   #11
Poogchomp
Poogchomp's Avatar
Drives: Chevrolet Ram 250
It depends how much they lower the car. RCE Yellows work fine with the stock struts and they lower the care by about 4/5 of an inch.
Poogchomp is offline   Reply With Quote
Old 01-23-2022, 01:45 AM   #12
ver22
Drives: Subs
Hello buddy
Sent from my iPhone using Tapatalk Pro
ver22 is offline   Reply With Quote
Old 01-23-2022, 12:29 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'd go 225/40-18 on 18x8. 245/35-18 is a bit too wide for 8", technically within the allowed width range tho...
Lowering only 0.5", you don't have to worry about stock suspension or drive/halfshafts. Or going to coilovers or struts/shocks. RS-R Down springs will lower you ~0.5". If you go lower than RCE Yellows (0.8"), IMO you'd wanna get Bilstein B6, or go coilovers due to stock struts having limited bump travel.
Old 01-23-2022, 06:02 PM   #14
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Not to hijack a thread but, how much can you lower a 2013 FRS without having to worry about camber etc?
coilovers, wheels and tires
WTB: STX Suspension (Coilovers) and Wheels+Tires Optimoose20 Want-To-Buy Requests 0 08-25-2020 04:56 PM
FS: Stock 2012 FR-S wheels/tires and Enkei PF01 Winter Wheels/Tires - Lexington KY deljaso Wheels and Tires 3 04-22-2020 09:33 PM
Remove P4S tires from my stock BRZ PP wheels and mounting snow tires? jredders Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-26-2019 12:30 AM
BC Coilovers installed-Stock Wheels/Tires continuecrushing Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2016 07:32 PM
