| Software Tuning Discuss all software tuning topics. |
Drives: 2020 BRZ/86, 2020 BMW 330i
EcuTek and Torque Pro monitoring oil temp
Hi everyone, I've got a question regarding the Torque Pro compatibility with the EcuTek. I've got a stock 2020 86 Base model and say I buy a Bluetooth OBDII adapter and get a Torque Pro app to monitor oil and coolant temps, will it work after a have an EcuTek tune or I'll have to buy their proprietary adapter and use their app?
#2 | |
Drives: 2018 Subaru BRZ Limited with PP
#3 | |
#4 |
#6 |
#7 |
Yeah, I was a bit surprised that it didn't have that fancy cluster with the display, but as long as there's a way to get those readings, it's not a big deal.
| The Following User Says Thank You to Arthur-A For This Useful Post: | Dzmitry (03-02-2021) |
#8 |
Drives: '14
For those who don't know:
If you have a jailbroken iPhone, you can use the tweak 'CarBridge' to display your EcuTek gauges (assuming you have the Bluetooth adapter) onto your headunit. |
#9 |
Just for FYI, usually you can not use two OBD2 devices at the same time . There are a few that will work together at the same time but one must be a monitor only. I have tried several using a "Y" cable. Where CAN buss is designed to work with many.
#10 | |
Drives: 2013 Subaru BRZ
Any hit to the data throughput especially for RPM logging? Sent from my SM-G965F using Tapatalk |
#11 |
I do not know about those two. As i said the only way is to try. Some you may think are read only are poling for information.
| Torque App not reading Oil temp properly | dazbrz | Engine, Exhaust, Transmission | 8 | 01-15-2021 08:03 AM |
| How is Torque Measured? (EcuTek) | Dzmitry | Software Tuning | 1 | 01-15-2020 10:36 AM |
| Worlds Highest Power and Torque FR-S Tuned on EcuTek | EcuTek | Forced Induction | 65 | 09-03-2015 01:19 AM |
| Torque app with oil temp | aaronsadventures | Electronics | Audio | NAV | Infotainment | 0 | 09-08-2014 10:14 AM |
| Engine oil temp now available in Torque App | Yruyur | Engine, Exhaust, Transmission | 8 | 02-03-2013 11:52 PM |
