Old 02-13-2021, 04:58 PM   #1
gshopper
Drives: 2003 330i, 2019 BRZ (blue, with PP)
JRSC and octane at the track
(this is crossposted to the forced induction forum, so sorry about the redundancy)
I have a 2019 BRZ which has been the track a few times (JR oil cooler, camber bolts, brakes and tires...otherwise stock). While I love the way the car handles, I wish it had a few more horsepower; I think around 250 would probably be the sweet spot for me. I don't need to be the fastest, but there are a lot of fast cars in my group, and it would be good to keep up with the pack. I do mostly HPDE's and a few days of open track. No racing, but I usually drive in the advanced groups.
I am thinking of getting a Jackson Racing supercharger. The instructions "REQUIRE a minimum of 50% 100 octane fuel" at the track. 75 to 100% 100 octane is recommended.
Some of the tracks I would be going to may not have 100 octane. Also, while I recognize that going to the track is not cheap, when I can get it, it is over three times the price of 93 octane.
Can a JRSC run 93 a the track? I don't need crazy horsepower, and I would be happy to sacrifice some power for a 93 octane track tune, if one exists.
What is everybody doing?
Thanks.
Glenn
gshopper is offline   Reply With Quote
Old 02-13-2021, 05:24 PM   #2
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Do you still have your catalytic converters? If not, one option is to use Boostane to cost effectively raise your octane to 100 at the track.
Alternatively, buy some gas cans and purchase your 100octane before going to the track and take your track fuel with you.
SCCA T4 - FRS
Old 02-13-2021, 05:26 PM   #3
gshopper
Still got the cats... but
"Jackson Racing supercharger systems require Premium grade (91 Octane or greater) gasoline, as does a stock FR-S/86/BRZ. Fuel quality is very important with a high performance application, so remember to only use a “Top Tier” gasoline. Do NOT use Octane Boosters in your fuel system. Octane Boosters will damage your spark plugs and your oxygen sensors when mixed incorrectly."
quote from JR installation manual
Old 02-13-2021, 05:32 PM   #4
Purist
Purist's Avatar
Drives: Subaru BRZ
E85?
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 02-13-2021, 07:53 PM   #5
gshopper
e85? Not really interested. Can’t get it where I am.
Need to focus on 93 octane gas.
The Following User Says Thank You to gshopper For This Useful Post:
Purist (02-13-2021)
Old 02-15-2021, 02:38 PM   #6
ML
ML's Avatar
Drives: 13 White MT FR-S
I have never ran more than 93 with the 12-10psi pulley, and have not had any knock issues. the base pulley should be even safer.
Old 02-15-2021, 05:13 PM   #7
gshopper
ML,
Is that for the street or track?
My car is my daily, but it would see track duty a few times a year.
Old 02-15-2021, 05:48 PM   #8
ninjan00dles
Drives: 2015 FRS
Get a custom tune from a reputable shop and tell them to build you a conservative tune for track use
ninjan00dles is offline   Reply With Quote
Old 02-15-2021, 07:08 PM   #9
ML
ML's Avatar
Originally Posted by gshopper View Post
ML,
Track use only, but like ninjanoodles said you should get a good tune to be safe.
Old 02-15-2021, 07:48 PM   #10
CSG Mike
CSG Mike's Avatar
The higher octane is safety margin. If you choose to roll the dice, you can do so, and many do successfully, but in the case of an engine failure due to knock/detonation, know that higher octane could have prevented that.
Race fuel, Race pads, Race maintence, makes sense, for a car being driven at a Race track.
Old 02-15-2021, 08:03 PM   #11
DarkSunrise
DarkSunrise's Avatar
The easiest way to tell is to datalog at the track and see how much knock you're getting on 93, and figure out how much knock you're comfortable with.
2022 BRZ Build
2013 FR-S Build
Old 02-15-2021, 09:28 PM   #12
CSG Mike
CSG Mike's Avatar
I'm not comfortable with any knock at all!
Remember, track driving will load the intercooler far more than street driving, which means higher intake temps, which means higher risk of knock/predet. Higher octane fuel means higher knock resistance.
It has nothing to do with the tune, and everything to do with the driving conditions.
hpde, jrsc, octane, supercharger, track
mixing e85 (109 octane) with e15 (91 octane) pcguru2000 Engine, Exhaust, Transmission 19 03-08-2022 11:35 PM
JRSC and octane at the track gshopper Forced Induction 15 07-28-2021 04:49 PM
Edelbrock vs JRSC for track Hades Forced Induction 21 02-21-2018 03:30 PM
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-31-2017 12:39 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 02:23 AM
