Old 11-16-2020, 07:36 PM   #1
golemslord
Drives: 2014 White FRS
valenti tail light install no torque wrench
Hi all, installed valenti tail lights at first with just a 8mm socket and hand tightening the screws (the best of my ability). Next day there seems to be a tiny bit of water at the bottom of the tail light but no condensation (due to heavy rain).
Following day, I then used a 1/4 drive ratchet and 8mm socket to tighten all screws. (all with a little less than a quarter turn)
My question is if that is too tight or just right or too less? I know it is suppose to be 39in.lbs or 4.5nm or 3.25ft.lbs but no idea what it feels like
Lights are purchased used but previous owner bought new 3 months ago
Thank you
golemslord is offline   Reply With Quote
Old 11-16-2020, 07:47 PM   #2
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Thank you
Are the gaskets the ones that came from the factory (ie. the ones previous owner used)? If so, you need to get a new set of gaskets. They get pressed the first time you tighten the bolts on install, and seal successfully. After that, the gasket retains the shape and is useless for next install. In other words, they are non-reusable and must be replaced each install.
Torque is 4.5 n-m or 3.3 ft-lbf (not tight at all). Still suggest a torque wrench but most importantly new gaskets.
Plumbus is offline   Reply With Quote
The Following User Says Thank You to Plumbus For This Useful Post:
golemslord (11-16-2020)
Old 11-17-2020, 05:15 AM   #3
golemslord
Yeah it's used gasket, I guess I'll get some 2017+ gaskets from Toyota. Also do I have to really use weather sealant? Can I just put the new gasket on tails and bolt it back on?
Old 11-17-2020, 08:33 AM   #4
StraightOuttaCanadaEh
Wes
Honestly I didn't use a torque wrench and don't remember anything about any gasket. Are these used ones you got?
Instagram: @gt86ws
Old 11-17-2020, 08:50 AM   #5
golemslord
yeah the tail lights are used for 3 months by previous owner. The gasket that comes with the valenti do seem like on a thinner side
Anyone know if doubling up the gasket would do the trick. I have additional spare first generation valenti gaskets that are pretty thin
Old 11-17-2020, 12:15 PM   #6
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Do not double-up. Gaskets are designed to seal against hard surfaces, not other gaskets. Use the gasket as it comes new. Just because it seems thin doesn't mean it isn't effective. If you align the gasket properly and don't over-torque it, it will be just fine.
sharpsicle is offline   Reply With Quote
Old 11-17-2020, 09:20 PM   #7
golemslord
idk man, I think I'm trolling myself. Apparently when I took one tail light off today, it looks like the water is actually at the inner edges of the lens. Therefore it made it seem like water was inside but not. No wonder why there was no condensation
Though, fingers crossed that I reinstalled it correctly again lmao
The Following User Says Thank You to golemslord For This Useful Post:
Wally86 (11-18-2020)
Old 11-18-2020, 01:13 PM   #8
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Not saying you're supposed to use a new gasket when reinstalling but... good luck!
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 11-19-2020, 05:31 PM   #9
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I've always had trouble with those gaskets.
OEM, then first generation of the Valenti Smoked both had condensation and water in them. The Smoked started cracking too.
Now I'm running Valenti Sequential clear and used Gasket Ninja and silicone/weather sealant. No issues at all now. There is a thread around here on what type of gasket material to use and you can just trace the old gasket out.
Clueless
YamahaR86 is offline   Reply With Quote
Old 11-25-2020, 12:09 PM   #10
RickyBobby
Drives: 2013 Firestorm FR-S AT
Due to an ahole backing in to me in a parking lot and needing body work, I've had my Valentis on and off twice, with the same gaskets. After 3 years, no water leaks. I used this torque wrench both times.
https://www.harborfreight.com/14-in-...nch-63881.html
Use code 32664366 at checkout to get 20% off.
RickyBobby is offline   Reply With Quote
Wiring & Splicing Valenti Revo SB2 tail lights to Valenti fourth brake light Ep140 Cosmetic Modification (Interior/Exterior/Lighting) 8 06-16-2020 06:05 PM
Valenti tail lights torque spec? Cothman4Life Cosmetic Modification (Interior/Exterior/Lighting) 3 09-08-2018 08:18 AM
Calculate torque when using a crows foot on torque wrench BirdTRD DIY (Do-It-Yourself) Guides 0 10-11-2015 05:02 PM
Flasher problem after Valenti tail light install! czechm8 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-27-2014 01:00 AM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 01:14 PM
