Old 10-18-2020, 12:51 AM   #1
SamtheKorean
September
SamtheKorean's Avatar
Drives: 2015 BRZ
Is my engine knocking?
Hello guys, always getting some good answers here so I’m gonna ask away. I’m currently running nameless long tube headers with oft stg 2+ 93 octane tune. Few days ago I’ve had p0030 popped up, I believe it’s my o2 sensor. I had the CEL for days and it went away by itself.. and now I’m just diagnosing everything and I noticed that my tablet shows KC learning number which is keep going up (anywhere from 0-6.00) during acceleration and sometimes I see anywhere from 0-2.00 briefly on knock corr column during acceleration. If anyone knows any of these symptoms it would mean a lot. Thanks guys
SamtheKorean is offline   Reply With Quote
Old 10-18-2020, 03:13 AM   #2
jason_456788
Drives: 2017 brz
KC learned goes up higher as you step the gas pedal deeper right?
Sent from my SM-N960U1 using Tapatalk
jason_456788 is offline   Reply With Quote
Old 10-18-2020, 03:38 AM   #3
SamtheKorean
September
Drives: 2015 BRZ
Yes it does and knock corr sometimes pop up as well
Old 10-18-2020, 05:24 AM   #4
jason_456788
Drives: 2017 brz
Same here. But without all your engine problems. So maybe it's not the cause of the engine code. Also, the code means you might have faulty o2 sensor. Hmm I'm not sure but I don't think youre knocking. Cuz when ur car knocks, you can tell it's noticable.
Old 10-18-2020, 07:07 AM   #5
Turdinator
Señor Member
Turdinator's Avatar
Take a log with the OFT and post it in the tuning section. You will soon get the answers you seek.
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
SamtheKorean (10-19-2020), Spuds (10-18-2020)
Old 10-18-2020, 09:36 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Does the IAM drop after a few minutes? Also a log would be great.
The Following User Says Thank You to Spuds For This Useful Post:
NoHaveMSG (10-19-2020)
Old 10-18-2020, 10:02 PM   #7
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I dunno but tell it to use the doorbell next time
TommyW is offline   Reply With Quote
The Following 8 Users Say Thank You to TommyW For This Useful Post:
humfrz (10-19-2020), JonAvalon (10-19-2020), NoHaveMSG (10-19-2020), SamtheKorean (10-19-2020), soundman98 (10-18-2020), Spuds (10-19-2020), Ultramaroon (10-19-2020), Wally86 (10-19-2020)
Old 10-19-2020, 01:08 AM   #8
https://yarn.co/yarn-clip/2bd891a1-3...byhhqqmFx.copy
Old 10-19-2020, 01:47 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
^^^^This. Post a log, be sure to read the sticky's in the software forum, otherwise it will likely be useless.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
SamtheKorean (10-19-2020), Spuds (10-19-2020)
Old 10-19-2020, 11:31 AM   #10
SamtheKorean
September
Drives: 2015 BRZ
so when the car is started it starts from .70 and it goes up to 1.00 after few minutes of driving and yes i’ll try to upload my log.
The Following User Says Thank You to SamtheKorean For This Useful Post:
Spuds (10-19-2020)
Old 10-19-2020, 11:33 AM   #11
SamtheKorean
September
Drives: 2015 BRZ
don’t have one but i’ll see if COBB sells a aftermarket one for my fa20
Old 10-19-2020, 11:43 AM   #12
Spuds
The Dictater
Spuds's Avatar
IAM is driven by the knock sensor and resets after a engine shutdown/startup cycle. I normally use that as a determining factor as to whether there is significant amounts of knock currently.
KC learned I believe is persistent across engine shutdown/startup, so those values indicate regions where it has detected knock from sometime between the last time you flashed and now. This indicates that your engine is already reducing timing in that region.
So with IAM at 1, and KC Learned at some value, it shows that your engine is not currently knocking, but has knocked at some point in the past.
Old 10-19-2020, 11:55 AM   #13
SamtheKorean
September
Drives: 2015 BRZ
Ah that makes sense, I know knocking in engine can cause by improper air to fuel ratio, do you think having a faulty upstream and downstream o2 sensor can cause this problem?
Old 10-19-2020, 12:16 PM   #14
Spuds
The Dictater
Spuds's Avatar
Yes, it is definitely possible. The more upstream sensor is the important one for afr as I recall. The one further downstream is just a check to make sure the cat is working , which I think you don't have. Running lean is likely to induce knock.
Any idea what your ltft is? It changes at different load values (load increases with airflow) so you might need a log to see it. Basically if your o2 sensor is messed up, you are likely to see large + or - values in your fuel trim.
FR-S engine rebuilt and knocking DJjoey0812 Issues | Warranty | Recalls / TSB 2 01-16-2020 07:46 PM
Rattle/knocking from engine (video) draculr Issues | Warranty | Recalls / TSB 24 08-06-2019 08:57 AM
Knocking Raspy Sound from engine bay 914_WHITE_FRS Issues | Warranty | Recalls / TSB 60 05-08-2015 01:30 AM
loud knocking constant with engine speed whatsmynameagain Issues | Warranty | Recalls / TSB 34 12-09-2014 10:58 PM
Engine knocking after flash Tenchi Software Tuning 10 09-26-2014 12:50 AM
