Old 04-15-2020, 01:38 AM   #1
2017BRZ4ME
2017BRZ4ME's Avatar
Drives: 2017 Subaru BRZ Limited w/perf pkg
Arrow Battery terminal covers
My very first post. I've owned my 2017 BRZ for less than a week!
I noticed what looks like a battery terminal cover that had fallen down in the corner of the battery tray. Where does this go? Do either of the battery terminals come stock from the factory? Hopefully the picture will show up here.
https://photos.google.com/u/0/photo/...sy6W5mxx5lmZoF
Send pictures of what the factory battery should look like.
Thanks in advance.
https://lh3.googleusercontent.com/Ki...w=w659-h888-no
2017BRZ4ME is offline   Reply With Quote
Old 04-15-2020, 03:13 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Welcome.
Read your manual if you have it. If not google it. It would provide useful information you need to know about your new car.
Also battery covers are red and are on the positive side of the battery. If that is what fell down then just put it back. Just google image any BRZ engine bay.
Also FYI in order to post pics you need to have them hosted via third party site like Flickr or such.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
NWFRS (04-17-2020), Ultramaroon (04-16-2020)
Old 04-15-2020, 03:36 AM   #3
JD001
JD001's Avatar
Drives: Subaru BRZ
I only have a cover for the 'postive' terminal, the cover is red..
Old 04-15-2020, 04:42 AM   #4
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Yes that red plastic thing is your positive battery cover.
The way it's sitting, it's upside down.
The longest part of the cover goes in front of your battery.
You many have to wiggle it into snap it back in place. That amp cable might get in the way. But just tell it "you're a naughty boy" and shove it in with force.
Old 04-15-2020, 11:30 AM   #5
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Have you ever tried clicking on the paper clip and just uploading a picture? It works well. It's how I posted the screenshot below. Not sure if a new member can do it right away, maybe need to make a few basic posts first.
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
JohnJuan (04-15-2020)
Old 04-15-2020, 12:27 PM   #6
You sometimes have to click on the "Advanced" tab of the post to get the paperclip. It doesn't show up in a basic "quick reply" post.
Old 04-15-2020, 01:43 PM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm still wondering if the OP has retrieved said item and managed to install it on the correct terminal.. Or has he broken it trying to fix to something else??
I think the cover for the "positive" terminal may come under the "worst design ever" because once installed you can't see the terminal!!
The Following 2 Users Say Thank You to JD001 For This Useful Post:
LimitedSlip (04-15-2020), Tcoat (04-16-2020)
Old 04-15-2020, 02:53 PM   #8
sneefy
Drives: Shopping for an 86
How about you Google it yourself?
sneefy is offline   Reply With Quote
Old 04-16-2020, 01:11 AM   #9
Man, that's too much work. Somebody help this guy.
Old 04-16-2020, 02:48 AM   #10
2017BRZ4ME
2017BRZ4ME's Avatar
I think the former owner added some wiring for his subwoofer. That may be what is making it difficult to seat the terminal cover. The cover doesn't want to fit over the area of the black tape just above the red insulation. I can force it to clip but it won't stay put. If I can determine which wire he added maybe I can remove it. That's why I was asking for a picture for comparing the stock wiring on the positive terminal. Thanks again.
Thanks for the tip on paperclip attachment photos!
The Following User Says Thank You to 2017BRZ4ME For This Useful Post:
JD001 (04-16-2020)
Old 04-16-2020, 04:00 AM   #11
JD001
JD001's Avatar
Drives: Subaru BRZ
This can be your very first mod... Cut red cap to fit around additional cables...
NWFRS (04-17-2020), ToySub1946 (04-16-2020)
Old 04-16-2020, 02:26 PM   #12
LimitedSlip
The red wire is not stock. Does the cable have sufficient length to move it to the clamp bolt?
The cover might fit better then.
tarzan_nojane (04-21-2020)
Old 04-16-2020, 03:21 PM   #13
JD001
JD001's Avatar
Drives: Subaru BRZ
Why are you so desperate to fit the cover? My cover usually spends more time in the door cubby hole..
The Following User Says Thank You to JD001 For This Useful Post:
Tcoat (04-16-2020)
Old 04-16-2020, 05:52 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Won't pass tech for basically any motorsports event without one.. slightly less likely to cause a fire in the case of an accident (ground to firewall/etc) is another.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
JD001 (04-17-2020), tarzan_nojane (04-21-2020)
Aftermarket Battery Terminal Covers YamahaR86 Electronics | Audio | NAV | Infotainment 0 02-07-2020 03:46 PM
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
Battery terminal setup fuddbutter Electronics | Audio | NAV | Infotainment 0 01-24-2017 05:27 PM
Lost my battery terminal nut. qqzj BRZ First-Gen (2012+) — General Topics 3 08-05-2014 08:51 AM
Battery Terminal for Amp Install rbizzle004 Electronics | Audio | NAV | Infotainment 3 06-05-2013 01:46 AM
