Meow
Drives: GT86 (now sold)
Car stalling after extended rest & battery swap
Hello guys,
It's pretty much all in the title. My car's been stopped since the beginning of the French lockdown about 6 weeks ago, and at the same time, its battery finally died (like dead dead, it's seven years old). It took me a while to source a new battery with the current conditions, but I finally received one (Varta D47 60Ah) today. The car was without power long enough for certain setting (AC, avg fuel economy) to reset themselves. I started it up and drove it for about half a mile, and it stalled on me a couple of time, both times with the clutch out, as I was getting to a stop or slowing around a low-speed turn. It also takes a second to find an idle once I lift off the throttle, and the revs dip down to 350-400. My first thought is to put that down to the ECU having to re-learn a few parameters after having finally started back up, so nothing to worry about. What are your thoughts? Best regards, Alex |
#2 |
Drives: 2013 frs raven
6 weeks is a long time there's likely bad fuel in it too. But it's likely a combination of both the fuel and ecu.
I would let it idle for a while (10 mins?) and then try to burn out that fuel. |
#3 |
Yeah between the computer learning again and fuel it could cause some hiccups. Can you get a fuel treatment or stabilizer? Seafoam, heet, something along those lines would probably help
Sent from my ONEPLUS A5010 using Tapatalk |
#4 |
#5 |
Famous Potatoes
Drives: '15 ultramarine
Sounds a lot like what my car does with the flex fuel kit when I go from e85 back to gas. Just relearning. Drive for a bit and I bet it goes away.
I doubt your gas is bad enough to do anything. If gas was bad, fuel stabilizers will not fix it. Those have to go in when the gas is good. |
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | alex87f (04-27-2020), sharpsicle (04-23-2020) |
#6 | |
ProCrastinationConsultant
it's just the car re-learning how to take it's first steps again.
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#7 |
Meow
I drove it a bit more the next day and it was already better. Still stalled once when braking to a stop (probably the brakes pulling vacuum just when the engine was at its lowest), but I think it'll be just fine.
| The Following User Says Thank You to alex87f For This Useful Post: | Tcoat (04-27-2020) |
| Battery Brace touched Positive Battery terminal, car won't start!! | 7m28 | Issues | Warranty | Recalls / TSB | 21 | 09-24-2017 01:55 PM |
| FS: KC Machine lightweight battery mount with Shorai battery and charger | toeout | Engine, Exhaust, Bolt-Ons | 4 | 04-23-2017 01:07 AM |
| DIY: how to replace battery for push start keys, and scion to toyota swap | 1GiantTurtle | DIY (Do-It-Yourself) Guides | 2 | 12-27-2014 01:24 AM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 09:26 AM |
| Window switches not working right after battery swap | jonbonazza | Issues | Warranty | Recalls / TSB | 9 | 01-10-2014 03:50 PM |
