Drives: 2015 Subaru BRZ (Manual)
What is this part on my bumper????
I'm trying to take the bumper off my 2015 Subaru BRZ and found this cover thing on it that is preventing me from taking it off (I don't want to go ape and rip it off destroying it). I searched on Subaru's parts and nothing is there and I've only seen this on some bumpers. I think it is the sensor for the headlights but I could be wrong.
#2 |
Drives: 2016 ice silver metallic
not a tow hook cover, right? (me too lazy to go outside and look at my car)
Sent from my SM-N950U using Tapatalk |
#3 |
No I don't think it is a tow hook cover I have one on the plastic part of the bumper
#4 |
Drives: RX-7 / BRZ
Its for euro spec cars with headlight washers/squirters.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#5 |
Drives: 2010 corolla
pez dispenser
#6 |
How would I remove this (do I need to disconnect a cable or pull it off etc...)?
#7 |
Drives: 2023 Toyota GR 86 Cup
It's a headlight washer...not sure how it is removed. I would remove the wheel and pull the fender liner to get a look at it.
2023 GR Cup Car
#8 |
Drives: MY14 86 GTS Manual Velocity Orange
Headlight washer. If you get your fingernails under them you might be able to pull them out far enough to remove the fluid hose that attaches to the back of them. they are spring loaded - in there firmly, pull them straight towards you and don't twist them like you have done in your photo. might have to leave them until you remove the bumper to get your hand behind there to remove them before taking the bumper off completely.
these covers are known to fly away, probably when the washers are used at highway speed. I have disconnected mine for this reason - on the passenger side (RHD vehicle) you can remove the plastic cover on the bottom side of the front part of the bumper (the cover in front of the aluminium sump cover). you will see the bottom of the washer reservoir under the passenger side headlight. remove the cable to the pump on the very bottom on the washer bottle and tape up both ends to stop dust getting in there. the washer bottle has two motors - one for the windscreen (higher up) and one for the headlights (the lower one). the headlight washer only works when the headlights are on and the windscreen washer is activated. No warning lights or anything following disconnection. |
| Bumper stay part number? | FR-Sky | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 02-14-2019 09:02 PM |
| Difference between bumper part number? | Drambeenie | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 01-19-2019 09:11 PM |
| Part # for Scion FR-S Front Bumper | 914_WHITE_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 05-06-2015 10:45 PM |
| Part Number for RS 1.0 Rear Bumper?? | jesse_86frs | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 02-20-2015 04:59 PM |
| Got hit (bumped)! Need part number for the black part of bumper. | scottsampaio.com | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-25-2014 12:05 AM |
