Old 09-15-2016, 04:47 PM   #1
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Aluminum Driveshaft Bolt Issues
I'm getting ready to install an Axle-Exchange aluminum driveshaft and recall reading that some people found their factory driveshaft mounting bolts to be too short when they installed their aluminum driveshaft. I think one member reported that he had to install them without washers in order to have enough threads to tighten the bolt, which is not acceptable to me. Can anyone share their experience and offer insight before I install mine? Do the factory bolts work or are they a compromise? Are the troublesome bolts at the output shaft, the differential, or both? If there's a problem using them, I can call ARP to get longer bolts, but I don't know what the bolt specifications are and don't yet have the bolts from my stick driveshaft in hand to be able to measure them - if anyone knows overall length, diameter, thread length, and thread pitch, please let me know.
Thanks for the help!
Last edited by RJasonKlein; 09-15-2016 at 04:49 PM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 09-15-2016, 11:02 PM   #2
makesdrivingfunagain
Thats a great question, I was actually thinking about purchasing a lightweight driveshaft after my gear install. Wasn't sure if you had a chance to give them a call and see what they said. I would like to know what they say since it is their product. I hope it goes well with the install. I like losing weight. It is easy to verify weight loss, as we dont have to rent out dynos to confirm a power to weight ratio improvement. Let us know how the install goes and how you like the mod. Thanks
2013 FR-S, AT, Braille 15lb battery, 16x7 Wedsport SA15R w 205/55/16 Continental Extreme Contact Sport, TRD drop in airfilter, TRD spring and TRD swaybars, TRD exhaust, TRD Brake Pads,4:56gear, 2740lbs
makesdrivingfunagain is offline   Reply With Quote
The Following 2 Users Say Thank You to makesdrivingfunagain For This Useful Post:
RJasonKlein (09-15-2016), SuperTom (02-16-2020)
Old 09-15-2016, 11:10 PM   #3
RJasonKlein
That's a great place to start, so I'll call Axle-Exchange and report back here with what they tell me. I called ARP this afternoon and they said it was likely that they'd have something that would work, but that I'd need to give them the bolt specifications for them to find a match. Because I haven't removed my factory driveshaft yet, I can't do that - like I said in my first post, if anyone knows the bolt specifications please let me know.
Old 09-16-2016, 12:14 AM   #4
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Just don't use the washers.
Old 09-16-2016, 11:18 AM   #5
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
Go hardware store, buy grade 8 bolts in the Length you need, Done!
Living the dream in a nightmare.
skye67 is offline   Reply With Quote
The Following 2 Users Say Thank You to skye67 For This Useful Post:
Mr.ac (02-20-2020), RJasonKlein (09-16-2016)
Old 09-17-2016, 04:31 PM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
My bolts were NOT long enough either.
Haven't purchased new ones yet, so I am unsure of the size.
The Following User Says Thank You to continuecrushing For This Useful Post:
RJasonKlein (09-17-2016)
Old 09-17-2016, 08:03 PM   #7
RJasonKlein
Originally Posted by Norville Rogers View Post
I think if you have these kinds of questions, and you are asking the internet for help, you probably shouldn't be considering this.
Oh, it's our British super-troll again...does every contribution you make to this forum have to prove your eligibility as a contestant in an 'asshole of the year' competition?
Well, we have a winner! Fuck off, mate - cheerio!
The Following 4 Users Say Thank You to RJasonKlein For This Useful Post:
Griever423 (02-14-2020), swarb (09-17-2016), Ultramaroon (09-18-2016), zc06_kisstherain (09-18-2016)
Old 09-18-2016, 04:36 PM   #8
ka-t_240
you can find the bolts you need at 95% of hardware stores, lowes, home depot, menards. No need for arp.
ka-t_240 is offline   Reply With Quote
The Following 2 Users Say Thank You to ka-t_240 For This Useful Post:
Mr.ac (02-20-2020), RJasonKlein (09-18-2016)
Old 09-18-2016, 06:41 PM   #9
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
I just installed the aluminum DS from Drive Shaft Shop. The plate at the diff end is thicker than the OEM DS, sounds like the one from Axle Exchange is too.
For mine, The factory nuts end up grabbing about 2/3 of the remaining factory bolt when keeping the factory washers on the bolt side. The factory used those extra-thick washers because the bolts sit in a notched recess. You won't get great purchase on the bolt heads if you remove the washers - your socket/wrench will only grab about half of the bolt head. Your mileage may vary.
note: the factory M10 bolts/nuts are 30mm in length, collared, 10mm diameter with 1.0 super-fine thread pitch, stamped grade 11 steel. The factory nuts are also collared. Apparently the factory nuts are NOT grade 11 steel, they were beginning to round off with my 14mm box wrench ( hand turned.) I replaced the factory nuts with some grade 10 nuts without collars. As they are 1.5mm thinner than the OEMs, they sit flush on the ends of the factory bolts using the DS mentioned above.
FYI There are no threads on the diff itself or the DS plate. You can easily swap to 10mm 1.25 pitch grade 10 bolts in lengths or 35mm or 40mm. ( I"m not an engineer, can't comment on any differences the thread pitch might cause.) These are much easier to find at a typical hardware store. I recommend you retain the OEM washers at the bolt heads to lift the bolt head out of the notched recesses in which they sit; other wise you lose 1/4 of the purchase (wrench contact) on bolt head.
Also, get the longest 14mm box wrench you can find; you will need the leverage to break loose the OEM bolts.
canyons is offline   Reply With Quote
The Following 4 Users Say Thank You to canyons For This Useful Post:
DreamSpeedBRZ (02-13-2020), RJasonKlein (09-18-2016), ryoma (09-18-2016), Turbo (08-11-2019)
Old 09-18-2016, 11:19 PM   #10
RJasonKlein
note: the factory bolts/nuts are 30mm in length, collared, 10mm diameter with 1.0 super-fine thread pitch, stamped grade 11 steel. The factory nuts are also collared. Apparently the factory nuts are NOT grade 11 steel, they were beginning to round off with my 14mm box wrench ( hand turned.) I replaced the factory nuts with some grade 10 nuts without collars. As they are 1.5mm thinner than the OEMs, they sit flush on the ends of the factory bolts using the DS mentioned above.
This is awesome information and exactly what I was looking for - I really appreciate it.
The Following 2 Users Say Thank You to RJasonKlein For This Useful Post:
canyons (09-14-2019), Turbo (08-11-2019)
Old 02-13-2020, 09:23 PM   #11
DreamSpeedBRZ
Drives: 2017 86
Has anyone addressed the issue of the color/dust cup on the spindle end? I'm about to install an aluminum DS and am slightly worried about the opening to the transmission being exposed to the elements.
DreamSpeedBRZ is offline   Reply With Quote
Old 02-20-2020, 12:47 PM   #12
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I removed my DSS aluminum drive shaft, when launching it the shaft would bang into the bottom of my stock shifter. Also found out on track it vibrated like a mother fker above 100 even after rotating it every which way.
Trueweltall is offline   Reply With Quote
Old 02-21-2020, 10:31 PM   #13
Contender
Drives: 2017 Toyota 86
I so much want one but, not if it vibrates like a mother fucker.
Contender is offline   Reply With Quote
WTB: Aluminum Manual Driveshaft kevin.nguyen Want-To-Buy Requests 0 06-05-2015 03:18 AM
Aluminum 1-piece Driveshaft Cjs_ Engine, Exhaust, Transmission 17 03-25-2015 05:45 PM
FS: Driveshaft Shop (DSS) aluminum driveshaft (for AT only) $350 dp1 Transmission and Driveline 8 06-18-2014 05:16 PM
