Old 04-25-2014, 01:27 PM   #1
Tyler.
Drives: 2013 blue fr-s 1983 supra.
Rattle/buzz with certain bass tones.
Does anyone else have issues with their stock system doing this? I've got the 2013 bespoke and even with the bass negative it will still rattle what sounds like the door panels like crazy. It's driving me nuts because I can't isolate it. Usually you can touch the panel or spot where its coming from and it will quit.
Tyler. is offline   Reply With Quote
Old 04-25-2014, 01:38 PM   #2
Skurj
Drives: SOLD...
mine does it, probably best way to get rid of it is to add a sub and remove the low freq's from the doors altogether
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 04-27-2014, 05:11 PM   #3
Tyler.
Can you do that though? I was looking through the bespoke options and didn't see a subwoofer section. Just tuning for front to rear.
Old 04-27-2014, 05:22 PM   #4
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
This was driving me crazy, I took apart both door panels and put some dynamat type stuff everywhere and siliconed all the groves where the panels met (the door panels are made of multiple plastic pieces).
I had to install / reinstall the panels a few times to get rid of all the rattles, now I can use the Bass all the way to the end if I want to with rattles in very rare istances. It was VERY worth it - my favorite "mod" so far as I'm quite the music lover, I don't even feel like having to upgrade the speakers anymore.
Rayme is offline   Reply With Quote
Old 04-27-2014, 07:30 PM   #5
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
OP, I suggest you turn off the stereo and confirm if the noise goes away or not during the same circumstances. I had/have a buzz in my car that I thought was the shitty stock speaker system for months; turned out to be a completely different issue.
Prog is offline   Reply With Quote
Old 04-27-2014, 08:36 PM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
Put pressure on the drivers side window switch panel when you hear the buzzing. I bet it goes away. There's a TSB for it.
Old 05-03-2014, 08:15 AM   #7
lionbacker54
lionbacker54's Avatar
Drives: 2013 WR Blue 6MT BRZ
i had a similar issue but it actually turned out to be the quarters i kept in the sidewell. bass notes made them rattle.
lionbacker54 is offline   Reply With Quote
Metallic buzz over 4000 rpm? Ingen Issues | Warranty | Recalls / TSB 37 11-21-2017 01:51 PM
Do we have bass?? Evo2Brz Electronics | Audio | NAV | Infotainment 34 04-02-2014 06:29 PM
Anybody Have this Buzz/Rattle? Gary in NJ BRZ First-Gen (2012+) — General Topics 8 10-07-2013 12:36 PM
Installed Amp & Speakers, getting constant buzz Gir Electronics | Audio | NAV | Infotainment 8 11-16-2012 02:28 AM
Continuous BUZZ/HUM from HPFP in ACC mode. stevo_12v AUSTRALIA 2 10-22-2012 05:46 AM
