Old 05-24-2013, 12:03 PM   #1
KBRZee
Drives: Satin White
Aftermaket dash speakers without cutting the factory harness
So Crutchfield sells a harness, Item# 12071042, for the dash speaker. It does not work. It fits the plug that goes to the 3.5 inch speaker but it doesn't work because the sound has to travel through the tweeter plug to get to the 3.5 inch speaker. No idea why they wired it that way.
I was about to splice the wire when I came up with this idea, that worked. I had some 14 gauge house wires laying around. I cut the ground wire into small pieces and bent them into a small horse shoe shape. Then I flattened them out with a hammer. I used them to bypass the tweeter plug so the sound can travel to the 3.5 harness, and then I used the harness from Crutchfield. Hopefully this picture can explain what I did better than I can.
KBRZee is offline   Reply With Quote
Old 01-21-2014, 01:21 PM   #2
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Any issues with this yet? How's it working for you?
Prog is offline   Reply With Quote
Old 01-22-2014, 02:48 AM   #3
KBRZee
Drives: Satin White
No problems at all.
The Following User Says Thank You to KBRZee For This Useful Post:
Prog (01-22-2014)
Old 10-16-2016, 09:10 PM   #4
Here2rock
Drives: 86 GTS
I am little confused as how the those "horse shoes" will fit the wire harness?
Here2rock is offline   Reply With Quote
Old 10-29-2020, 05:04 AM   #5
Compelica
Compelica's Avatar
Drives: 86 GT
Bringing this back up from the dead... but if anyone wants a quicker solution to this, spade connectors will also work nicely. Just slot them in and secure with tape.
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
soundman98 (10-29-2020)
No dash speakers Gir AUSTRALIA 65 03-28-2013 07:15 PM
Coxial Components and Dash Speakers Gopherboy6956 Electronics | Audio | NAV | Infotainment 24 03-27-2013 06:46 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 07:31 PM
BeatSonic Dash/Harness Kit and Pioneer AVH-X550BHS.. help! brianlo622 Electronics | Audio | NAV | Infotainment 19 02-17-2013 10:54 AM
Dash speakers? SteveGrillo Electronics | Audio | NAV | Infotainment 11 02-01-2013 11:51 AM
