Old 07-22-2019, 05:41 AM   #1
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Upgraded fuel pump with stock injectors?
Hi guys, haven't been in here for awhile. It's time for me to replace my fuel filter, and I figured i might as well upgrade the pump whilst at it. However, is it possible to run a slightly bigger pump (i.e. DW65c) whilst still retaining stock injectors?
Theoretically, if a car was tuned with stock pump and injectors, will upgrading fuel pump require re-tune?
(I have no intention of getting larger injectors, at least not for the time-being)
Fizz is offline   Reply With Quote
Old 07-22-2019, 06:24 AM   #2
86MLR
86MLR's Avatar
I haven't heard any issues with the stock pump.
Stock pump flows enough for around 300whp.
If you are planning boost and E85 then maybe, but that again depends of flow requirements.
I would look at:
1. the reliability of the OEM pump and how much whp it will support on 98 ron and E85.
2. How much flow you will need when you do upgrade
From there I would see what is the best and most reliable solution.
If it's not needed, more money for other required supporting mods, or beer.......my vote is for beer.
Old 07-22-2019, 08:18 AM   #3
steve99
Drives: FT86
If the fuel pressure remains same it should be fine, ie you retain the sandard fuel pressure regulator in tank.
Theirs been a few issues with DW pumps , thte oem pump seems pretty reliable.
The SBD turbo guys seem to prefer the walbro pumps if you were to upgrade..
But doent seem necessary in your case
stock injectors & fuel pump peaches Engine, Exhaust, Bolt-Ons 13 03-31-2020 05:45 PM
FS: stock injectors and fuel pump xsnapshot Engine, Exhaust, Bolt-Ons 2 01-06-2016 06:14 PM
WTB: Stock injectors and fuel pump willharp360 Want-To-Buy Requests 3 12-10-2015 09:50 PM
Wtt upgraded fuel pump & injectors misooscar Brakes, Suspension, Chassis 0 04-09-2015 05:35 PM
FS: Stock Injectors and Fuel Pump carlossanchez89 Engine, Exhaust, Bolt-Ons 1 12-03-2014 04:28 PM
