Drives: Toyota 86 GTS
Rattle/knocking from engine (video)
Hi there, I've had this very intermittent engine knocking sound on my 2017 Toyota 86 (it's still under warranty so I'd like to identify what's happening so I can take it to the dealer). It happens quite rarely as in once per trip and usually doesn't happen when the car is warm, nor does it happen on a cold start.
I'm happy to have finally caught it on video! You may need to turn the volume up as it was recorded by phone from inside the car. [ame="https://www.youtube.com/watch?v=AVJHevOBogo"]https://www.youtube.com/watch?v=AVJHevOBogo[/ame] Does anyone have any idea what this is? Should the dealer be able to diagnose it from this video? |
#2 |
Drives: BR86
Manual ? Possibly clutch or flywheel.
#3 |
#4 |
Drives: BR86
If you press clutch in does it go away ? Hot idle revs are pretty low causing some vibration which transmits to the rest of the driveline including clutch & flywheel which are known to rattle sometimes especially on 1st gen Hachis.
I would say typical/normal but please get the dealer to confirm it. |
| The Following User Says Thank You to ZZT86 For This Useful Post: | Ultramaroon (08-05-2019) |
#5 |
#6 |
I'm not hearing anything unusual -
![]() humfrz |
#7 | |
I've booked some time in with the dealer and at least now I have some information for them. Cheers mate! |
#8 |
#1819
Drives: Lightning Red Subaru BRZ
Sounds to me something is loose or unbalanced.
#9 |
Okay the dealer has reproduced the issue and has booked me in for a release bearing replacement under warranty.
I'm wondering since they have to pull the gearbox out to do the job if it's worth me having them replace the clutch itself? The part should be fairly cheap I imagine but then again the car has only done around 28,000km (17k miles). |
#10 | |
#11 |
So the dealer service changed the throw out bearing under warranty but it has not fixed the issue. I was surprised they thought it was the TOB since it usually makes sound with the pedal depressed I imagined?
Anyway, they want to book it in to look at again and I made them this video: [ame]https://www.youtube.com/watch?v=bGjnfPUqWoo[/ame] It still goes away when the pedal is depressed. Does anyone have any insight into what it may be that's loose and causing this rattle? The rattle starts occuring 5 minutes after a cold start (I just let it idle for 5 minutes) and seems to go away when the car is properly warmed up. |
#12 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | draculr (08-05-2019) |
#13 | |
Shame on the dealer. Sad waste of money.
| Another knocking/rattle issue | Grunger | Issues | Warranty | Recalls / TSB | 5 | 03-31-2018 11:47 AM |
| rattle/knocking sound while parked/ in drive | dalli | Issues | Warranty | Recalls / TSB | 38 | 03-17-2016 09:39 PM |
| Engine knocking after flash | Tenchi | Software Tuning | 10 | 09-25-2014 11:50 PM |
| Knocking/Rattle on start up. | jimbobrand | Issues | Warranty | Recalls / TSB | 18 | 01-13-2014 11:34 AM |
| Front KNocking Noie and Gear Lever rattle | Naughty | AFRICA | 17 | 10-26-2013 02:56 PM |
