Drives: Silver 2013 BRZ limited
Alignment question after swift sprigns
So I had an alignment done when i got my swift springs install. They printed out a sheet and I never bothered to look at it.
Anyways, what made me look at the sheet again that sat in my glove box was the fact that i noticed on my rear, one wheel seemed more camber than the other. It was slight but I personally noticed it. Im pretty much a noob still on alignment and i read the sheet. it says left rear -2.14 degrees and right rear -2.29 degrees. IS there a reason they did it that way? |
#2 |
Drives: '13 DGM BRZ Limited
There is no camber adjustment in the rear unless you get LCA's or UCA bushings. Some have used a modified camber bolt on the subframe to LCA mount as well.
#3 |
#4 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
i also had unequal rear camber after spring installation; i had LCAs installed to equal them out. from talking to folks who have had springs installed, it's more common than not, to end up with unequal rear camber. the difference from one side to another varies; mine was about .25° different from one side to the other.
#5 |
Dirt Trackin'
Drives: '13 Raven FR-S MT
That's not a huge difference in camber anyway. I wouldn't be overly worried about it.
#6 |
Drives: 2013 Black BRZ Limited
Honestly, I think you're running too much camber in the rear. I could be wrong, but my handling improved a great deal once I got my rear camber around -1.5. It also helped to have it equaled out and running a bit of toe in. I think getting some camber adjustment bushings or a rear LCA would really help out the consistency of your handling, although that's just my experience with the platform.
#7 |
So if i get LCA's in the rear I can adjust camber? Which ones are good?
Also what about the front, I want to camber it a little, what should i go with up there? |
#8 |
For LCA's, I went with the SPC arms as they are ~$200 and get the job done. You can look at others like Cusco, RacerX, GTWorx, etc. as well.
For the front, just get the OEM crash bolts or some camber bolts. |
#9 |
I went with the OEM crash bolts and SPC rear LCAs as well. It was the most cost effective and easiest install option there is currently, but any of the rear LCAs will do the job.
#10 |
thank you =)
#11 |
Drives: '23 BRZ
~-2.2 camber isn't a big deal, and will give greater ultimate grip vs. less camber. Honestly I wouldn't bother with getting components to "correct" it. What does the rest of your alignment look like?
#13 |
Drives: WRB LMTD '13
#14 |
Drives: '23 BRZ
| alignment question | hanabie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-15-2013 01:52 PM |
| (GOOD QUESTION) Which Spring make a higher front bumper? Tein H tech, RS-R or Swift? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 08-14-2013 10:52 PM |
| Alignment question | retrosmiths | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-11-2013 11:44 PM |
| toe, camber, castor? basic alignment question? | rainmonkey | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 05-18-2013 02:38 AM |
| RCE vs Swift: Any Insight? | boredom.is.me | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 03-24-2013 09:45 PM |
