Drives: Raven
low coolant level
Dealer burp the radiator after 50 miles, coolant level is low again and no sign of leakage. Internal leak ?
#2 |
What do you mean by "low"? Low in the reservoir? Low in the rad? How low is "low"? Have you checked with the engine both hot and cold?
| The Following User Says Thank You to Tcoat For This Useful Post: | FRS_KOTO (02-27-2019) |
#4 |
Wheels for Brains
Per the manual, you're supposed to top off the overflow reservoir when it's cold.
| The Following 2 Users Say Thank You to EndlessAzure For This Useful Post: | DarkPira7e (02-27-2019), FRS_KOTO (02-27-2019) |
#5 |
It is supposed to be low in the reservoir when cold. It works by pushing coolant into the reservoir when it get hot and expands. When the engine cools down it sucks it back into the rad. It is an expansion reservoir so that it doesn't just spill onto the ground when the engine is hot. It is not a fill to this line type situation like brake fluid or such. Even when the engine is hot it will not always fill the reservoir since there is no set amount of flow back and forth. As long as there is some in there at all then you are fine. If you fill it too much when cold then it will just push the excess out when it heats up.
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | eastendraceshop (02-27-2019), FRS_KOTO (02-27-2019), humfrz (02-27-2019), RL_BRZ (02-27-2019), strat61caster (02-27-2019) |
#6 |
Drives: Black frs
I’ve noticed there is about a two inch difference in the reservoir between hot and cold engine.
I’m about 1 inch below the full line when engine is cool and 1 inch above the full line engine is hot. I think if you are between the low and full line when the engine is cold in the reservoir, you should be fine. |
| The Following User Says Thank You to Silverz For This Useful Post: | FRS_KOTO (02-27-2019) |
#7 |
Leave the cap on. Service the resivior. There can be air trapped in the system with multiple heat and cool cycles it will work its way out.
| The Following User Says Thank You to Grady For This Useful Post: | FRS_KOTO (02-27-2019) |
#8 | |
Maybe you are just really old with cars? In that case, back in the old days, radiators didn't have separate overflow reservoirs, the expansion of the coolant was dealt with in the top of the radiator. Now, if you are new to cars (and that's OK, we all were new at one time - it took me a while to learn the pedal dance in our model T - ), I suggest you read the manual carefully and if you have any questions (after doing a search) post up your question here on the forum and someone will help you out.humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | FRS_KOTO (02-27-2019) |
#9 |
Drives: Raven
Dealer says, they had to call a subie tech since the valve spring replacement procedure doesnt include the re burp radiator process. “ special procedure “ due to an angled radiator on these vehicles. Anyway, dealer added coolant for the second time and will check back tomorrow if coolant level slurp it again . Thanks everyone for jumping in and appreciate your kindness and feel younger with greyed hair .
| The Following User Says Thank You to FRS_KOTO For This Useful Post: | humfrz (02-27-2019) |
#10 | |
Drives: Raven
#11 |
Drives: Black frs
When I changed my radiator fluid and had to follow the procedure outlined in diy section which involved running the heater, releasing the air, refilling the radiator and reservoir a few times.
| The Following User Says Thank You to Silverz For This Useful Post: | FRS_KOTO (03-01-2019) |
#12 |
[insert cool phrase here]
Drives: BRZ Premium
Here is the simple fix for under $1
Go to any supermarket Buy distilled water Open hood Pour in a cup or two to the coolant reservoir Problem solved. If you want to be a high roller Go to any Toyota/Subaru dealership and/or online -$40ish Buy coolant Open hood Pour in a cup or two Problem solved. All cars no matter how modern will use up a small amount of coolant. Due to simple evaporation. Since it's mostly water. Water near hot objects such as engines or anything that gives off heat will have an evaporating effect.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | FRS_KOTO (03-01-2019) |
#13 |
If you keep adding water you end up deluding it to much and next thing you know your pump is gone. Doubt you would use this much but it’s best to just go the high roller route.
#14 | |
Therefore, if the loss is due to evaporation, it would be OK to top it off with distilled or demineralized water. However, if the loss is due to leaking, it might be best to top off with the store bought blue stuff. ![]() humfrz |
| Low Coolant level @ 20k? Help.. | Jfheisenberg | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 10-29-2021 01:01 PM |
| Coolant level dropping & Dirty coolant | redwine | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 44 | 09-30-2018 09:37 PM |
| Low coolant level? | brzzy | Engine, Exhaust, Transmission | 7 | 04-11-2016 03:16 PM |
| Should I be concerned with coolant and oil level? | B-R-Z | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-28-2014 01:03 AM |
| Coolant level when cold | GloriousJ | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 05-29-2013 09:03 PM |
