Drives: WRB LMTD '13
Intake Cam Sprocket failure
Dropped my car for valve springs recall and was told that my intake cam sprocket was broken and had to be replaced.
Dealer told me Subaru would cover half of the portion, and dealer would take off the labor cost. However, I am still liable for some portion plus tax ($200ish) Car is 68k miles 2013 brz. Is this common to have cam sprocket failure? Is this something I can fight for it to have my portions waived? Thanks
#2 |
Drives: 2019 Mazda Miata RF
#3 |
How did it break? Did it break during disassembly?
Codes or issues prior to recall work? |
#4 |
#5 |
Could be one of the cam sprockets that had issues from the beginning, and the valve spring recall work put it over the edge.
#6 |
Drives: BRZ DGM Limited
If your car was fine with no codes before you brought it in for the recall, then they broke it during the recall work and you should not have to pay for the repair!
| The Following 2 Users Say Thank You to BRZnut For This Useful Post: | gravitylover (02-25-2019), Gunman (02-25-2019) |
| First Drive - CEL - Cam Sprocket Fix | TeamSweet86 | Issues | Warranty | Recalls / TSB | 113 | 09-30-2018 09:49 AM |
| Timing chain sprocket tooth broke | Jamesallen45 | Issues | Warranty | Recalls / TSB | 9 | 08-28-2018 04:24 AM |
| traction light, engine light = cam sprocket , ecu | nivek111070 | Issues | Warranty | Recalls / TSB | 27 | 03-13-2016 09:28 AM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| FA20 Cam Sprocket Question | pleong | Engine, Exhaust, Transmission | 4 | 01-24-2015 08:48 AM |
