Drives: 2017 BRZ
2017 brz trapezoidal opening - Scosche SU2032B Dash Kit - any alternatives?
Hey, I just installed this today with my sony XAV-210xm HU. While it looks ok, It steals some depth and makes access to the controls unhappy. Like they needed to let the stereo sit forward about 10mm. The knob which I went for because I am a knob guy is now this little nub buried deep in the face of the bezel. Bah!
https://www.crutchfield.com/S-eyhfrp...-Dash-Kit.html So I was wondering if anyone knew of a alternative. I know, 200mm wide hu but its too late for that
#2 |
Drives: 2017 BRZ
Also thinking if maybe this will fit a 2017 brz and be double din exactly.
http://www.ft86speedfactory.com/toyo...l#.XBWj9lw3mCo |
#3 |
[insert cool phrase here]
Drives: BRZ Premium
Go to the hardware store buy some washers, maybe get some longer bolts.
Stack washers behind the mounting plate. They hard part maybe finding washers that would fit, but a little super glue should hold them in place.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | humfrz (12-16-2018) |
#4 | |
- THAT is just too old school and waaaaay too simple!humfrz |
#5 | |
Drives: BRZ Premium
#6 | |
![]() Speaking of mounting radios, brings to mind my HS experience with the radio in my 1948 Chevrolet. During the week, I would take it out of my car and mount it on the fender of the tractor to play while I was working the fields. On a clear day, I could get three AM stations, two of which were country-western, complete with the farm reports. Then on the weekends (if it were raining) I would mount it back into the car for the Saturday night date and a Sunday drive. Hey, I was lucky - I had a car - with a radio - ![]() humfrz |
#7 |
Drives: 2017 BRZ
the Scosche kit is meant to be held captive inside the trapezoid frame. So spacing it out won't do anything, it would just push the whole assembly backward unfortunately. I am a master of the DIY so I even started modelling a better setup for my 3d printer that would let the radio come forward, or a new knob extension that I can glue atop the other one. But, the frame in a frame looks pretty bad. I also wanted this thread to be a warning to anyone thinking the Scosche SU2032B Dash Kit was the be all end all.
| The Following User Says Thank You to dma550 For This Useful Post: | humfrz (12-16-2018) |
#8 | |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
NOTE: Will not fit Subaru BRZ with Starlink radio. You aren't using a Starlink but was there one in there to begin with? Might need to contact FT86 Speed Factory and ask what causes the incompatibility. Probably just the trapezoidal shape of the Starlink. If the dash trim is truly Toyota OEM then it won't be double DIN but 200mm instead. Last edited by LimitedSlip; 12-16-2018 at 03:52 PM. |
#9 | |
Drives: 2017 BRZ
#10 | |
Drives: 2014 Subaru Forester
https://www.japanparts.com/parts/detail/43320 http://www.ft86speedfactory.com/suba...2013-ft86.html This is another option for using a double din head unit. I think the community has been long wishing for a standard sized double din, single piece dash option. I've been bugging a certain person to produce one... |
| The Following User Says Thank You to tehShirt For This Useful Post: | Drambeenie (12-19-2018) |
#11 |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Drambeenie (12-19-2018) |
#12 | |
Same here! Or that Subaru didn't make one. I had a 2014 WRX before the BRZ and Subaru Japan sold a double-din dash piece. @Drambeenie we need you! |
| The Following 2 Users Say Thank You to tehShirt For This Useful Post: | Drambeenie (12-19-2018), Racecomp Engineering (12-18-2018) |
#13 |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
If only we knew a vendor who could go to say, Metra or Scoshe and convince them that the math works.
#14 | |
![]() - Andrew |
| One piece dash and other 2017 parts | Summerwolf | Cosmetic Modification (Interior/Exterior/Lighting) | 340 | 05-05-2020 09:47 PM |
| opening 2017 brz foglight assembly | Breadman | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 10-22-2018 11:02 PM |
| 2017 BRZ Headunit (and Dash!) Replacement | Dok Henz | Electronics | Audio | NAV | Infotainment | 105 | 04-14-2018 01:23 AM |
| Anyone have a night photo of the 2017 dash? | ~el~jefe~ | BRZ First-Gen (2012+) — General Topics | 14 | 12-15-2016 04:01 AM |
| Scosche touchscreen A/C controller | DIREWOLF | Electronics | Audio | NAV | Infotainment | 46 | 03-30-2013 08:42 PM |
