Old 10-06-2018, 12:44 PM   #1
michael_basden
Engine failure
Has anyone else experienced this? My car is 6 years old, 160,000 km, well-maintained, and just had a bearing failure. It's catastrophic and they're quoting me $8,000 to replace the engine. At this point, it's not worth replacing it and so the car is basically scrap.
I've seen some videos on YouTube with the same condition and the same result I was just curious to know how prevalent this is with these cars.
Mike
Sent from my ONEPLUS A3000 using Tapatalk
michael_basden is offline   Reply With Quote
Old 10-06-2018, 01:01 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Just swap a used engine from a wrecked brz.
What bearing failed? What were you doing when it failed? What were the environmental conditions when it failed? Oil starvation is not uncommon, but would likely not occur in a well-maintained, street-driven car, so can you indulge more?
Old 10-06-2018, 02:08 PM   #3
WRBrzRX
Drives: runs&drives
Sounds like you spun a rod bearing. Plenty of us have, while plenty of us have not. Personally I'm on motor #3, I've blown a 13 (even more common) and a 16 with a Jackson dual rad and e85 keeping things cool. The rod bearings suck.
Because of the RTV everywhere these are horrible to rebuild. Prices were decent for engines before (low 2ks) and we've seen just as many built engines pop that it was common to just replace. Prices are now much more, perhaps demand is better understood by vendors or it has ramped up as more pop.
WRBrzRX is offline   Reply With Quote
Old 10-06-2018, 02:36 PM   #4
michael_basden
Thanks for the info.
I'm half considering taking the car back as is and doing some other kind of engine swap. I just think it might be a bigger pain in the ass than it's worth.
Old 10-06-2018, 02:57 PM   #5
WRBrzRX
Drives: runs&drives
If I had to do it all again I would LS/2J swap right out of the gates.
Old 10-06-2018, 06:58 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
$8k? That a hell of a lot money. You can always take it to any mechanic shop for a lot less.
These engines are super easy to remove.
As others said you can find a used one for cheap. Or if you are mechanically inclined do the labor yourself and have a shop rebuild the engine.
Engine failure Geex Issues | Warranty | Recalls / TSB 19 07-01-2018 04:57 PM
Engine failure! mackeye Engine, Exhaust, Transmission 24 01-30-2018 12:48 AM
Engine Failure (Bearing Rod 2) Incursion Issues | Warranty | Recalls / TSB 59 11-27-2014 03:17 PM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 03:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
