FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue
As the title states... I'm wondering if the BBK from the '17 Performance Package BRZ will fit into the BRZ STI wheels from the Series Blue. 17x7 5x100 +48... I have a feeling the offsets may be different but I need someone who can actually confirm it.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#2 |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Nope they won't, you'll need a spacer to run them
#3 | |
FT86Club Vancouver
Thanks!
#4 |
#5 |
Drive From Home
Drives: BRZ STI Performance
They won't clear, that's why the STI JDM site mandates 18" x 7.5J for the optional Brembos.
#6 | |
FT86Club Vancouver
All the numbers look the same but the width of the wheels which are 0.5 wider than the ones I've got, so I was just curious if that is the deal breaker for the BBKs.
#7 | |
Drive From Home
Interesting cuz back when they only made 7.5J for both 17" and 18", STI recommended 18" for the Brembos. Now they revised the website and states the following: ※ You can not set standard wheeled wheels. Replacement with Brembo Brakes Aluminum Wheel is required. Corresponding STI aluminum wheel part no. 18 inch: ST28100MF250, ST28100MF260, ST28100MF270, ST28100MF280 17 inch: ST28100MF050, ST28100MF060, ST28100MF080 * BRZ tS standard component Item No.: ST28100MF050 PT Silver 17 × 7.5J + 48 PCD100 5 hole Product No .: ST28100MF060 Gunmetalic 17 × 7.5J + 48 PCD100 5 hole Product No .: ST28100MF080 Black 17 × 7.5J + 48 PCD100 5 hole http://www.sti.jp/parts/subarubrz_zc/brake/26100AS000/ http://www.sti.jp/parts/subarubrz_zc.../ST28100MF050/ Dam that means I can get the Brembo option and my ST28100MF060 rims will fit!
#8 | |
Drives: between cars...
#9 |
Drive From Home
#10 |
FT86Club Vancouver
Gawd damn... Lol Stupid USDM 17x7... Why U no add 0.5 to the width!? xD
I have a feeling the tS Brembos are bigger than the Performance Package BRZ Brembos. Hmmm...
#11 |
Drive From Home
The link I've provided is for the tS standard Brembo brakes and it's clearly saying on the fine print that you need 17" x 7.5J.
| The Following User Says Thank You to krayzie For This Useful Post: | Clipdat (03-23-2017) |
#12 | |
FT86Club Vancouver
I wonder why they went ahead with the 18 inch wheels for tS then. Hmmm.
#13 |
Drives: wrx, brz
If this is anything like the brembos on the WRX STI then it's not wheel diameter you're worried about, it's spoke clearance. The calipers are wider and won't clear depending upon spoke design. Wheel width and offset are irrelevant.
On those setups you'd need a 5mm spacer to clear with factory rims, not sure about the BRZ PP setup but I'd guess it's the same. |
#14 |
Drives: 2017 BRZ Limited
Anyone know if the Brembo BBK will fit into a regular 2017 with non-PP wheel?
| 2017 BRZ Performance Package Brembo Brakes Part Numbers | Veloist | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 146 | 04-27-2023 10:36 AM |
| Specs for BRZ Performance Package wheels? | ~el~jefe~ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 04-17-2020 07:31 PM |
| WTB: OEM 2017 Performance package wheels | mjanmohammad | Want-To-Buy Requests | 1 | 03-03-2017 03:35 PM |
| BRZ Blue.Series STI Wheels | Wyattkb | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 01-04-2015 12:16 AM |
| FS: BRZ Blue Series wheels | RogueBRZ | Wheels and Tires | 26 | 09-11-2014 06:29 PM |
