Drives: Wrb 2014 limited brZ
Crawford ecoblocks
Saw recent facebook posts regarding this new time semi-available by Crawford.
A stock 2014 sti saw 15hp gain and 18lbs of torque for the cost of $50 and an under $5 installation. I guess it's a maf sensor but I'm not entirely sure what it does. It also can see ~7% increased mpg. It only works on the stock intake. They said it should be available on their website this weekend but are taking orders by phone. Any thoughts? If no problems arise, it is undoubtedly the best bang for the buck mod and I'm curious what kind of numbers it can pump on in a twin. Even a 5hp gain to the wheels would be awesome. |
#2 |
Drives: Scion FR-S
I imagine this is a mod that only works untuned because it's tricking the computer doing the air/fuel calculations in some way.
I personally wouldn't do it, a tune seems like a safer more reliable way to get these gains. |
#3 |
Drives: 2013 asphalt scion FRS
Every thing I've ever seen from Crawford does BHP. Not WHP. So in reality at 15 claimed horsepower, your actually only getting a 2-3 bonus to the wheels
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
#4 |
Crawford makes them for the twins but they're far from $50 and $5 installation. Believe they are called Crawford Billet Power Blocks.
#5 |
Yes this only works without a tune.
The billet blocks are a different product. This is a new product that they have been working on for years, apparently. 2-3 hp for $50 isn't bad. Consider this and a k & n filter and you have 8ish hp for under $100. |
| The Following User Says Thank You to dtrop For This Useful Post: | SkAsphalt (12-29-2014) |
#6 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Not sure if I should be suspicious or excited...
#7 |
Drives: FT86
Looks like a spacer fitted to maf sensor.
Suspect it shifts maf sensor slightly out of the main air flow in intake. Suppose this would make the sensor detect slightly less air flow, ecu would then be fooled into injecting slightly less fuel as the air flow detected by maf sensor would be less but the actual air flow would be same. Maf sensor also used as input to engine load calculation so it going to shift a lot of things like timing vvt and ignition arround. Probaby relies on most stock turbo cars running rich for safety so leaning it out theoreticly gets you better economy and a bit of power. it all seems a bit dodgy would it work with a stock 86/brz who knows but gains if any would be less than turbo car. Last edited by steve99; 12-21-2014 at 03:57 AM. |
| The Following 4 Users Say Thank You to steve99 For This Useful Post: |
#8 |
Drives: 2015 Series.Blue
Pretty sad seeing a product like this from a reputable company...
I want to use worse language, but I'd rather not be banned. |
| The Following 7 Users Say Thank You to Poodles For This Useful Post: | bcj (08-11-2018), Calum (12-21-2014), cdrazic93 (12-21-2014), Manji (12-29-2014), SomeoneWhoIsntMe (12-22-2014), Sportsguy83 (05-23-2017), Tristor (03-30-2018) |
#9 | |
Yes, it seems a bit sketchy, but what problems could this actually cause? |
#10 | |
Drives: FT86
This spacer it appears will just artificially offset the maf scaling, could possibly cause drivability problems or just may not work at all on a non boosted car. |
#11 | |
#12 | |
Possibly. The issue here is that it's frankly dangerous to do stuff like this. It's stuff I've seen hack job "tuners" do instead of actually tuning a car. For starters, their claims of increasing horsepower, increasing gas mileage, and decreasing emissions is 100% BS. If this was the case, the multi billion dollar car companies would have noticed this and done it themselves. The government breathes down their neck about emissions and MPG figures. In reality though, it probably doesn't do much of anything as MAF sensor is in the tip of the pillar, so even if you pull the MAF out a bit, it's still reading the air the same. Of course, there's always the possibility it's true and works (kinda like their power blocks, though I'm still not sold on those either). |
| The Following 5 Users Say Thank You to Poodles For This Useful Post: | cdrazic93 (12-21-2014), kodyo (12-21-2014), SomeoneWhoIsntMe (12-22-2014), steve99 (12-21-2014), Tristor (03-30-2018) |
#13 |
Junior
Drives: a car
Ahh beat me to it.
#14 | |
Drives: FT86
| The Following User Says Thank You to steve99 For This Useful Post: | kodyo (12-21-2014) |
| Crawford AOS with FBM kit | whitefrs | Forced Induction | 40 | 10-14-2015 07:32 PM |
| WTB: Crawford BPB | v86 | Want-To-Buy Requests | 0 | 07-20-2014 10:59 PM |
| Crawford AOS | Thechow | Engine, Exhaust, Bolt-Ons | 2 | 06-23-2014 06:24 PM |
| FS Crawford AOS | whitefrs | Engine, Exhaust, Bolt-Ons | 4 | 07-04-2013 11:31 AM |
