Old 07-02-2019, 08:15 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Tyre storage and shelf life.
I have 4 track day tyres (Hankook Z214) in the shed. They are mounted on rims, inflated and lying on their sides. They are unused but I'm guessing they might be 2 years old.
What sort of shelf life/ best before date do tyres have?
Ta.
Old 07-02-2019, 08:36 AM   #2
Vesartis
Vesartis's Avatar
Drives: 2016 Subaru BRZ Series.HyperBlue
Ta.
The general advise for in-use regular passenger tires that are being driven on the street is that 10 years is the absolute max , but you should replace or inspect thoroughly after 5-6 years.
Track tires can be a little more sensitive, because they are made from compounds that are focused on grip instead of a long life. But tire sellers often store tires for a year or two before they are sold, so what's important to check is when the tires were made. The sidewall has a 4 digit DOT code that will tell you this. First two digits are week of the year, second two digits are the year. So if the tires were made in the 31st week of 2016, the code will read 3116. If that was more than 5 years ago, then you would have to be a little more careful.
As long as they haven't been exposed to extreme temps (extended below 40F or direct sunlight) they should be okay as long as they pass a visual inspection. Maybe grip levels will be less then when they were new.
Vesartis is offline   Reply With Quote
OFT: Off-The-Shelf v2.072 maps now available Shiv@Openflash Software Tuning 22 02-13-2017 05:21 PM
Tyre Stretch, make ride higher? Bulgy tyre Codythatsme Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-20-2016 10:56 AM
Brake Fluid shelf life? VoiD Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-02-2013 06:17 PM
HKS SUPERCHARGERS ON THE SHELF! 3 AVAILABLE SCIONPRO D2BD Motorwerks Forced Induction 7 07-01-2013 01:45 PM
Garage Life: We bring your dreams to life! Garage Life Southern California 0 08-17-2012 07:33 PM
