Old 05-16-2018, 05:34 PM   #1
wparsons
wparsons's Avatar
AC failed under 6 years.
Went to use the AC the other day, only blowing pure hot air. It sounds like the compressor is cycling on, but it might be a relay clicking. There's a hissing sound from behind the dash, only when AC is on.
Is there any known issues to look for? From what I can guess, the system still has pressure if the compressor is actually cycling on. Possibly the condensor?
flickr
Old 05-16-2018, 08:16 PM   #2
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
need to vacuum out and refill your freon
malubawla is offline   Reply With Quote
Old 05-16-2018, 10:29 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Fail? More like you ran out of the refrigerat.
Either take it to a shop or buy a refill kit at any auto parts store and do it yourself.
Old 05-16-2018, 11:00 PM   #4
I'd suggest you take it to a shop and have them "fix" it.
See ...... how simple that is ......
wparsons (05-16-2018)
Old 05-16-2018, 11:51 PM   #5
wparsons
wparsons's Avatar
Would the compressor clutch still cycle on if it was out of refrigerant? My understanding is that there's a pressure switch and the compressor clutch wouldn't engage if there's no pressure in the system?
flickr
Old 05-17-2018, 12:08 AM   #6
Grady
Grady's Avatar
If it is cycling it probably just low on refrigerant. The low pressure switch is probably around 5psi. No need to vacuum if the system still has pressure. If it continues to leak down and you replace a part then replace the reciever drier and vacuum it down prior to service.
The Following User Says Thank You to Grady For This Useful Post:
wparsons (05-17-2018)
ABS C1288 - ECU Matching failed MatGO Issues | Warranty | Recalls / TSB 21 05-30-2022 10:19 AM
Hlep. I failed. Shaisters Northwest 14 06-02-2016 11:56 PM
Nameless overpipe/downpipe welds failed and perrin endlink failed stockysnail Northwest 4 01-14-2016 07:27 PM
Failed Inspection with a tune... Shady195 Scion FR-S / Toyota 86 GT86 General Forum 19 06-10-2015 05:25 PM
Failed login notification griffinnn Site Announcements / Questions / Issues 6 02-18-2015 09:21 PM
