Old 04-18-2018, 05:51 PM   #1
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Turbo Suspension
So I finally boosted my BRZ. The turbo spools fairly quickly (I think) around 3500-4000.
I have 18x9.5 all around and some (probably terrible tires). I assume tires are gonna be a big part of it, but I was wondering if anyone can offer some suggestions on how to add some grip and stability to the car now that it is turboed.
So far I have:
Exhaust (Ultimate Racing
Headers (Gruppe-S)
Turbo kit (Ultimate Racing)
18x9.5 (Miro 111)
Coilovers (Tein Street Basis Z- starters for now)
Shift Bushing (whiteline)
Short throw (Top Speed)
Master Brake Cylinder (Radium)
Oil Catch Can (Mishimoto)
Other small upgrades that don't pertain to suspension
I was looking at sway bars, but never made the purchase.
Basically, is there anything I can upgrade to help maintain the balance of the car now that it is boosted? I don't know enough about suspension even after reading up on it quite a bit (Damn cars and unlimited knowledge). I assume the biggest thing to do is get some real tires on their first, but hoping to make the car just as good as it is without turbo power.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 04-18-2018, 11:14 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Answered your own question.
Tires. Get sticker ones
What size do you have on now? Please don't tell me is smaller than a 235.
The Following User Says Thank You to Mr.ac For This Useful Post:
Leonardo (04-19-2018)
Old 04-19-2018, 10:51 AM   #3
StraightOuttaCanadaEh
Wes
tire pressures are also important. My tires were squirrelly as hell when they were up to 36 psi. Lowered them to 32 and the grip improved. Experiment
Instagram: @gt86ws
Old 04-19-2018, 11:01 AM   #4
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Play with tire pressure, get a better alignment, buy stickier tires.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
SkAsphalt (04-20-2018)
Old 04-19-2018, 03:01 PM   #5
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Stickier tires.
Camber bolts or camber plates for front camber adjustment.
Rear LCA to adjust camber.
Hold off on the sway bars unless you know what they do and how it pairs with tire compound. People sometimes go too stiff and overwork the tires resulting in less grip overall.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Old 04-19-2018, 04:31 PM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Tires + alignment
Get some toe-in on the rear, minimum 1/8" (~0.3 degrees) total imho
I've got more on my car and a whole lot less power
Ride heights and crossweight could be playing a factor too along with damper settings and tire pressures and sway bars. There's no reason that with good tires you can't have a setup that's stable.
ineedyourdiddly
Old 04-19-2018, 09:54 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
Tyres and an alignment are a great place to start. If traction is an issue you can see if softening the damping on your rear shocks help. I don't have experience Tiens tho so its something you will have to have a play with.
1974 TA22 Celica
2013 86 GT
Old 04-20-2018, 02:42 AM   #8
Strife26
Strife26's Avatar
Thanks all for the responses. I will try all of these and wait on the sway bars.
Old 04-20-2018, 03:11 AM   #9
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
People choose to have toe-in on their cars? SMH.
Old 04-20-2018, 06:15 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
jsimon7777: many on rwd cars dial in slight toe-in for a bit more stability. Heck, even stock alignment is:
Toe (Each Wheel): C + D: 0°10' +/- 0°15' (0.16° +/- 0.24°)
Toe (Total): 2.0 +/- 3.0 mm(0.0787 +/- 0.1181 in.)
Imho nice article.
Old 04-20-2018, 10:09 AM   #11
cjd
cjd's Avatar
Drives: 2017 BRZ
Rear? Yes. Makes the car less skittish under power and can result in faster lap times. At least, done right.
The Following User Says Thank You to cjd For This Useful Post:
Strife26 (04-20-2018)
Old 04-20-2018, 11:35 AM   #12
venturaII
venturaII's Avatar
In most cases, 'done right' means 'virtually none', if you don't want to numb up response. I think zero is the ideal number to shoot for, personally, if you're concerned with keeping a lively feeling setup and still have decent tracking.
Old 04-20-2018, 01:13 PM   #13
strat61caster
Incredible as it may seem, some people don't place high value on tire longevity.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
EAGLE5 (04-20-2018), wparsons (04-20-2018)
Old 04-20-2018, 02:21 PM   #14
cjd
cjd's Avatar
Drives: 2017 BRZ
I run what probably amounts to zero toe with a toe-in bias in the rear, but will be experimenting again this year with more. However, I autocross - and setup requirements are different than what might be fastest on a traditional race course. Ultimately fastest may be zero toe, but I'd guess that a little toe-in will be more consistent for drivers that aren't perfect - and that's most of us; certainly is me. I forget what happens to toe under compression, but that also plays a role.
Also, for street, I'd nearly always recommend a touch of rear toe-in.
And absolutely not toe-out in the rear.
Looking for OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 1 01-06-2018 12:43 AM
OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 3 10-04-2017 07:56 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 11:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
