Old 04-16-2018, 09:43 AM   #1
MarkR171
MarkR171's Avatar
Drives: '05 Elise
2017+ Reliability Improvements?
Did Subaru/Toyota do any changes to the 2017+ engines for reliability? Ignition coils, cam gears, oil control valves, etc? Or is it still the same and one should expect the same recurring issues?
I had a 2015 that was in and out of the dealership for warranty repairs including a replaced short block that did not solve the issue. I liked driving the car and would consider a 2017+ if the reliability issues were addressed.
This has probably been asked before and I should probably expect some "gtfo and search" posts, but I did and didn't find much.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 04-16-2018, 10:13 AM   #2
gtengr
Drives: 2017 BRZ
I've attached the pdf that covers all the changes. Read through it and decide for yourself if your concerns have been addressed. Anecdotally, I haven't seen much in the way of issues on the +2017's. I have about 9k miles on mine and no issues so far. Some of the mods from the 2013-2016's don't fit without tweaking.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
MarkR171 (04-16-2018)
Old 04-16-2018, 10:22 AM   #3
JIM THEO
Drives: BRZ 2018
Revised valves (buffed and polished intake and exhaust valves) and camshaft (lower friction camshaft and lower weight rocker arm pivots), cylinder blocks with increased rigidity, greater piston durability, optimized fuel pump drive cam / upgraded fuel pump and fuel pressure sensor are some of them!
JIM THEO is offline   Reply With Quote
Old 04-16-2018, 10:40 AM   #4
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Thanks for this. Looks like the changes were more extensive than I thought.
Also looks like different cam gear, but whether or not it addresses that issue is in the air. New harness also so maybe it addresses the '15 TSB for coil packs?
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
2017 facelift gt86/brz sound deadening improvements rsingh Scion FR-S / Toyota 86 GT86 General Forum 4 03-27-2018 10:55 AM
2017 Model Year Improvements FiReStorm2013 Scion FR-S / Toyota 86 GT86 General Forum 353 03-11-2016 03:07 PM
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 09:55 AM
Small Improvements? ButtonMasher Tracking / Autocross / HPDE / Drifting 1 06-25-2014 01:55 AM
cheapest HP improvements for under $500 Salgts86 Member's Car Journals 31 01-31-2014 01:18 AM
