Drives: 2000 Subaru Legacy B4 RSK (JDM)
Sebring, BRZ & Tarmac II's
So I'm attending my first HPDE in a twin and was wondering if anyone had any setup recommendations for one running RCE Tarmac II's. (Bump & Rebound).
All my previous HPDE's were in a 3,600lb AWD understeering pig (in the background of the pic below) so the transition to a RWD over-steering BRZ should lead to a fun weekend.
#2 |
Drives: Car
The settings in the manual are a good starting point. Tune to preference/track from there. Since Sebring is a bit bumpy you might want to bump back compression/rebound a couple clicks. Of course the rest of your setup will also determine how your dampers are set.
| The Following User Says Thank You to FirstWinter For This Useful Post: | Opie (09-17-2017) |
#3 |
Drives: None
Opie... do you work at a subie dealer?
I bought your LGT if you are who I think you are...
#4 |
#5 |
I's start here and add bump in 2 click increments. I would NOT rely on rebound to calm the car thru turns 17 and 1. Seems like backwards thinking but it works.
Front rebound 10 clicks ( from full stiff) Front bump 12 clicks Rear rebound 13 clicks Rear bump 8 clicks. Randy Pobst ran the Chin Motorsports car there and loved it. That car DID have 500 lb springs on it and ran close settings to this but with 3 clicks MORE bump damping. Myles |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#6 |
Thanks Myles! I actually had the Chin car at my house for a few months (I fixed a tranny issue for them that came up at the May Sebring event) and loved it, I am building my BRZ using a lot of info I learned from the Chin car.
My BRZ is currently set as you listed above, alignment & corner balancing was done today. Ready to go get some seat time in a week and a half. |
| The Following User Says Thank You to Opie For This Useful Post: | Racecomp Engineering (09-20-2017) |
#7 | |
Drives: 2013 Raven FR-S
#8 | |
Drives: None
Moved to Chicago about two years ago. I sold the car about two years after I bought it from you. Added a DP and TMIC and a tune for a little more power, but left it pretty much as is otherwise. It was very tastefully modified so I didn't need to do anything. ![]() Looks like we both wanted to move to something lighter and more fun! I got my FRS a few months ago and have taken it to a couple of track events. A ton of fun so far. Good to reconnect again! |
| The Following User Says Thank You to Jamestl For This Useful Post: | Opie (09-21-2017) |
#9 |
#10 | |
Drives: Car
I've been thinking about going from 400/400 on my T2s to something stiffer like 504/616 (9k/11k). You have any experience with that set up on the T2s? I'm looking for a little bit more rotation and it still isn't quite there with the Perrin RSB I have on now. I might play with the damper settings this weekend though to see if I can get it just where I want it. Last edited by FirstWinter; 09-21-2017 at 02:37 PM. |
| The Following User Says Thank You to FirstWinter For This Useful Post: | jmark (09-21-2017) |
#11 | |
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | smg1138 (09-21-2017) |
#12 | |
The Stig's German cousin
| The Following 2 Users Say Thank You to renfield90 For This Useful Post: | FirstWinter (09-21-2017), Racecomp Engineering (09-21-2017) |
#13 |
Drives: Car
I use the car primarily on the track. Don't do as much autox anymore. I was looking at starting with 500 lb in the rear and tuning from there with the rear swaybar. I'll definitely give it a try first before going higher.
#14 |
Drives: 2023 BRZ
Man, that just seems like a setup that would understeer much more than I would want and certainly more than my car does. Even with 1* more camber in the front than the rear and no toe my car on T2s with standard springs and suggested settings understeered more that I like.
| RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 589 | 11-21-2021 05:13 PM |
| ***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 208 | 09-30-2016 04:43 PM |
| Sebring Pic | gatorac | Tracking / Autocross / HPDE / Drifting | 1 | 04-28-2016 08:03 PM |
| Newbie set-up for Sebring, Help! | maj75 | Tracking / Autocross / HPDE / Drifting | 40 | 04-16-2013 11:44 AM |
| Sebring with Dave-ROR | LDadrenaline | Tracking / Autocross / HPDE / Drifting | 9 | 11-13-2012 11:55 PM |
