Old 11-10-2018, 03:31 AM   #1
rydollasign
Drives: 2014 brz limited
break in period for transmission?
hey guys,
I got my transmission replaced due to a 4th gear grind issue covered under warranty and was wondering if there was a "break in period" for the new transmission? Im thankful it was replaced under warranty. the shifts are butter smooth now.
any feedback would be appreciated.
thanks
rydollasign is offline   Reply With Quote
Old 11-10-2018, 03:43 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's in your manual. Simple stuff huh?
Old 11-10-2018, 11:22 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
My manual states that you need to make several hard stops from 60-5mph as a break in procedure and to bleed the fluid to remove any air pockets if the pedal seems soft.
Wait no, it says that the car comes equipped with a 12v power sou- shit, just realized I can't understand an index. Sorry OP, Did you check Google?
Old 11-10-2018, 03:49 PM   #4
Well now, rydollasign, as far as I know, there isn't a formal break in period for this MT. However, I would suggest you read over some of the suggested shifting procedures mentioned on this forum. Hint #1 - timing is everything - .
@Mr.ac - I don't see any reference to a transmission break in period (procedure) in my 2013 FR-S manual. Do you want to help me out here or are you just yanking on the OP's chain? -
@DarkPira7e - I suggest you have at least 2 cups of coffee before posting -
Old 11-10-2018, 08:58 PM   #5
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
@humfrz it's a little of both really. But the actual brake in period is the same for a new car engine. Nice low revs till you hit 1k. Or what ever it is. Engine and tranny are grouped in, as so I read it to be.
So wasn't that easy?
Also.....can I interest you on a new Civic Si, you don't have to worry about weak trannies, , Civic trannies are 90% bulletproof you know?
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (11-11-2018)
Old 11-10-2018, 10:41 PM   #6
No need to be extra gentle but there is actually something to consider with a new MT. Unless the balk rings were pre-lapped by hand before final assembly, the syncros will continue to improve for several thousand miles before they grab well and the transmission really shifts the way it was designed. Mine didn't start shifting well until about eight thousand miles and kept improving through 15-17 thousand.
humfrz (11-11-2018)
Old 11-11-2018, 01:12 AM   #7
Well, OK - it could be read thatta way.
Well now, about that Civic Si. Does it come with crickets? How are the valve springs?
It is a handsome vehicle, which I may consider, if they fuck up my FR-S by changing the valve springs -
Do you have a blue one in stock?
Brink (11-11-2018), JMon85 (11-12-2018)
Old 11-11-2018, 02:01 AM   #8
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
No crickets. No reported issues yet.
Yes blues are in stock.
humfrz (11-11-2018)
Old 11-11-2018, 06:08 AM   #9
rydollasign
I appreciate the info guys!
The Following User Says Thank You to rydollasign For This Useful Post:
humfrz (11-11-2018)
Old 11-11-2018, 06:39 PM   #10
Did you just make that up ? -
Sapphireho (11-11-2018)
Old 11-11-2018, 08:33 PM   #11
humfrz (11-12-2018)
Old 11-11-2018, 08:42 PM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Engineers...
humfrz (11-11-2018)
End of break in period TOLM Scion FR-S / Toyota 86 GT86 General Forum 29 01-16-2018 06:27 PM
Break in Period Pegasus Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 03-23-2014 05:25 AM
Break in period KonTheory Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 02-05-2014 01:03 AM
Break-in period...what's really going on? CaptainSlow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 04-27-2013 02:43 AM
Break-In Period UriarteMD Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2012 04:26 AM
