Old 05-22-2017, 05:03 PM   #1
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
HELP! How to get rid of poke
Hi I have 17x9 +35 offset rpf1 and it's poking really bad, im on stock suspension and have tein flex a's waiting for install how do I get rid of the poke I didn't realize how ugly and serious it was as I'm not really a wheels guy. So would camber help?
mulekr1 is offline   Reply With Quote
Old 05-22-2017, 05:16 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Car runs almost no camber from factory. 4x4 ride height in stock form doesn't help the look either.
When the car is lowered, the suspension will naturally increase negative camber and will get you closer to the look you desire. When the coilovers come in, install those along with LCAs and get and alignment.
You'll be set after that.
Old 05-22-2017, 05:28 PM   #3
mulekr1
mulekr1's Avatar
Thanks so basically I need a rear LCA now ( cheapest option would be SPC ) and get a performance alignmen? Thanks for the quick reply so I know what to order.
Edit; forgot to mention I'm lowering the car by an inch max.
Old 05-22-2017, 05:31 PM   #4
PeterFRS
PeterFRS's Avatar
Drives: FRS
may be able to get a way without LCA..
I'm on Tein StreetFlex and with the rears lowered at my height, without replacing LCA
I had natural? camber at -2.2 i think they were which I'm okay with.. and toe are not out of whack either
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 05-22-2017, 05:36 PM   #5
mulekr1
mulekr1's Avatar
Thanks for the reply I really don't want to wait for the LCA anyway because I already have everything for install just need the LCA if it's necessary I might try it without the LCA
Old 05-22-2017, 05:42 PM   #6
swarb
At an inch max you probably won't need lca, but if you want it perfect it is a good idea to have them. Even stock, they can be off by .2 to .3 degrees on each side.
After you lower it, the poke will be reduced due to the added camber. The tops will be tucked in further, but the bottoms of the wheel will be about the same. The camber creates an illusion of what is vertical so it will look better.
Old 05-22-2017, 07:27 PM   #7
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
what size tires are you running?
(Unless you posted them and I just can't see... my work computer is picky when it comes to that sort of thing..)
JeremyR is offline   Reply With Quote
Old 05-22-2017, 08:18 PM   #8
TylerLieberman
Drives: '24 GR86
There's no reason to not get LCAs. Don't be cheap.
Lowering the vehicle will change the alignment, likely causing the left to be different from the right. It has nothing to do with zero'ing camber. It's about making sure both sides are the same. $200 SPCs and be done with it.
Or spend $150 to get an alignment and find out theres a 1/2 degree difference, go buy LCAs, and then spend the money for an alignment again.
Old 05-22-2017, 10:39 PM   #9
PeterFRS
PeterFRS's Avatar
Drives: FRS
but i like my nascar alignment!
jokes. yeah if you have the means do it right!
'14 Scion FRS
Tein Flex
TE37
Old 05-23-2017, 12:32 AM   #10
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Who sold you the wrong wheels? This car has no business with 9" wide wheels unless it is a track car. You'll need to run greater than 2 degrees camber for them to "fit"
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 05-23-2017, 11:45 AM   #11
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
17x9 +35 245/40/17 all around lowered on swift springs only.
VenomRush is offline   Reply With Quote
The Following User Says Thank You to VenomRush For This Useful Post:
Vic4uf (05-30-2017)
Old 05-30-2017, 09:40 PM   #12
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I've got 17x9 RPF1 +35s. Really the only way to eliminate poke completely is investing in coilovers and camber bolts and finding the right alignment, there is a very small sweet spot where the top of the tyre is tucked and there is no rubbing on full lock.
Wise is offline   Reply With Quote
Old 05-31-2017, 12:00 AM   #13
Vdub
Driver of Sweet Vehicles
Vdub's Avatar
Drives: 2017 Pure Red Subaru BRZ Ltd w/ PP
Send a message via ICQ to Vdub Send a message via AIM to Vdub Send a message via MSN to Vdub Send a message via Yahoo to Vdub
Put in a spacer of around -15mm of width on each wheel and that should help even it out.
Vdub is offline   Reply With Quote
Old 05-31-2017, 08:18 AM   #14
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Please elaborate.
How to fix wheel poke tskaohu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-10-2016 02:58 PM
Immobilizer - where is it? How can i poke at it? im_topher Engine, Exhaust, Transmission 8 11-10-2015 12:29 PM
What can I do about poke? Don't know what I'm doing rinnamon Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 04-05-2015 09:38 PM
Poke's BRZ build Pokeguyjai Member's Car Journals 5 03-15-2014 11:10 AM
Help with poke on rear Ash.B Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 11-23-2013 07:19 AM
