Old 02-17-2017, 03:37 AM   #1
Zeezy
Drives: Black 86 GTS
Issues with new wheels.
Hi Everyone,
I recently got my car some new wheels (Enkei RS05RR - 18 X 8.5) and some new tires (Kumho Ecsta Le Sport - 245/40/18).
After having the tires and wheels installed, I noticed my car was riding really bumpy. At first I thought I was being paranoid but it seems the bumpy ride persists even on smooth roads.
It feels as if I am constantly running over bumps no matter what the condition of the road. The bumpiness seems to be coming from the rear right wheel (driver side) as I didn't feel the bumps when I rode in the passenger side. The bumpy feeling is not transmitted through the steering wheel, but can be felt from the seat. The bumps are also more apparent at low speeds, but can also be felt at higher speeds.
Anyone got any idea what might be wrong?
Thanks.
Zeezy is offline   Reply With Quote
Old 02-17-2017, 03:46 AM   #2
Maybe the wheels and tires are too big for the car ........ .....
I'd suggest you check the pressure in all of the tires.
Maybe have them re-balanced.
Rotating the tires may help in detecting the bad actor.
You might have a tire that is defective (out of round).
Come back.
Zeezy (02-17-2017)
Old 02-17-2017, 03:54 AM   #3
Zeezy
Hey, thanks for the reply!
I've checked tire pressure 35 psi all around so that shouldn't be an issue.
I've already contacted the tire people, but it's Friday so I have to wait till Monday to get a response.
anyway of checking if the tire is out of round?
I'm hoping it's the tires, cause they're easier to replace.
Thanks again.
Old 02-17-2017, 04:08 AM   #4
Thanks again.
The best way of checking the roundness of a tire is mount it on a spin balancer.
You could do a "quick & dirty" check by jacking up a corner and spinning the wheel against a straight edge.
Oh, yes make sure all the lug nuts are tight .....!
I hope you get it sorted out soon so you can enjoy your new wheels.
Zeezy (02-17-2017)
Old 02-17-2017, 07:03 AM   #5
swarb
You can also swap wheels to another corner to see if it changes anything.
The Following User Says Thank You to swarb For This Useful Post:
Zeezy (02-17-2017)
Old 02-17-2017, 07:49 AM   #6
osidak
Drives: '17 BRZ w/PP
Don't have my car yet so haven't even paid attention - does Subaru use Hub Centric or Lug Centric wheels.
If your new wheels don't match they may not be centered on the hub and would cause an in smooth ride
osidak is offline   Reply With Quote
The Following User Says Thank You to osidak For This Useful Post:
Zeezy (02-17-2017)
Old 02-17-2017, 08:03 AM   #7
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
On the twins its hub centric wheels. Hub rings that fill the gap are recommended but not mandatory. All the lug nuts are tapered so in theory it should center the wheel without needing hub rings.
Shneegle is offline   Reply With Quote
The Following User Says Thank You to Shneegle For This Useful Post:
Zeezy (02-17-2017)
Old 02-17-2017, 11:20 AM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
It's still possible to get them off center, especially if you don't gradually torque them in a 5-star pattern (torque all to ~40lb*ft > torque all to 88lb*ft).
I'd still highly recommend centering rings on these cars.
I got mine (aluminum) from Counterspace Garage and they fit perfectly! No vibrations at all!
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Zeezy (02-17-2017)
Old 02-17-2017, 11:55 AM   #9
........ pay attention, there, @swarb , I already mentioned that in post #2.
swarb (02-17-2017), Zeezy (02-17-2017)
Old 02-17-2017, 02:14 PM   #10
Zeezy
Already got aluminium hub centric rings for these wheels, so we can rule that out.
I also did more testing and it seems the wobble/bumpiness is most apparent around 15 - 20kmh (9 - 12mph), but is still noticeable at higher speeds.
I would like to refit the wheels myself but unfortunately I don't have a torque wrench.
Still open to other suggestions. Cheers for the reply guys!
Old 02-17-2017, 02:25 PM   #11
Yoshoobaroo
TRACKBREAD
There's a ~1ft wrench in the trunk. Put about 100lbs worth of force on the end of it, that should be close enough to ~90 lbf*ft.
olsonpg (02-17-2017)
Old 02-17-2017, 06:38 PM   #12
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
ez
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 02-18-2017, 02:01 AM   #13
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Does your steering wheel pull to one way or the other? maybe your camber. I could be wrong =/
FR-Sky is offline   Reply With Quote
Old 02-18-2017, 02:18 AM   #14
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
maybe it wasnt balanced?
went to america tires and they balanced my wheel completely wrong and my car rode like hell
My gas issues... DrunkBandit Northwest 15 06-14-2016 03:18 AM
Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? Eazy-V Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 11-02-2014 10:42 PM
Issues with Color on XXR Wheels Killerbee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 04-12-2014 12:17 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 04:41 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 11:08 PM
