Drives: Black MT LMT BRZ
Installing coilovers in a few hours. Anything I should know?
Soo I'm going to be attempting to install tein flex z coilovers in a few hours.. I'm new to modding cars. And have never really dome things like this. My frirmd is helping me. Is there anything I should know the diy post doesn't cover. I'm also painting my headlight housings black while doing this.
#2 |
Drives: '05 Elise
Focus on one thing at a time. Any job with cars thats listed as taking X hours will take 2X hours. The diy post is probably fine, coilovers are fairly straightforward as long as you follow instructions. Just make sure you get an alignment after.
'05 Lotus Elise
'19 BMW M2C '22 Subaru WRX ex '15 Scion FR-S |
| The Following User Says Thank You to MarkR171 For This Useful Post: | Kendallkab (01-14-2017) |
#3 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
^thats good advice. Everything will always take longer then the DIY says, especially if it is your first time and you are new to working on cars.
Also, when installing the rear make sure your parking brake is off. |
| The Following User Says Thank You to finch1750 For This Useful Post: | Kendallkab (01-15-2017) |
#4 |
[insert cool phrase here]
Drives: BRZ Premium
Research, look at vids, diy's, read up, do your homework, get all the tools you would need. Take your time. Don't do two things at the same time. Work on your coil overs then work on your shitty headlights
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following 2 Users Say Thank You to Mr.ac For This Useful Post: | Kendallkab (01-15-2017) |
#5 |
keep a jack handy for the rears. you might need to jack up the rear lower control arms into the mounting point for the rear coilovers. also get a strap tool so that you can tighten the top nut of the coils without spinning the shock shaft. if the coilovers are non-adjustable and have a hex insert, then get a pass-through socket and a hex wrench to tighten it. spinning the shock shaft too much might blow the seals on it. if the coilovers are adjustable, do NOT use a hex tool to hold the shaft from spinning but use the strap tool instead
| The Following User Says Thank You to ryoma For This Useful Post: | Kendallkab (01-15-2017) |
#6 |
Everything went great. I hear it noise like metal hitting metal when I'm on bad roads tho. How do I fix?
#7 |
Off Topic
| The Following User Says Thank You to gramicci101 For This Useful Post: | Kendallkab (01-16-2017) |
#8 |
^that
| The Following User Says Thank You to finch1750 For This Useful Post: | Kendallkab (01-16-2017) |
#9 |
Sounds good.. as soon as I have access to the tools again I will.
#10 |
Drives: 2017 BRZ
#11 |
The metal sound is gone.. I just hear popping sometime now.. any way to make that go away I would just like to know what it's coming from
#12 |
Drives: 2013 satin white brz limited
Check your struts top nut to make sure they did not loosen up on you.
#13 |
Powered by Crickets
Drives: 14' SWP MT Limited BRZ
I had a clanking metal noise every time I hit a bump when I installed my coils. Turns out I didn't torque down the top nut on each tophat. That's probably your issue.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
#14 |
The Stig's German cousin
Double check that your front sway bar isn't making contact with the control arms. This happens on some twins, especially when lowered. The solution is shorter endlinks.
To hell with the torque spec on the endlinks, get them on as tight as you can with a socket or wrench. They like to come loose. If you want to definitively identify this as the source of the noise, drive around with them disconnected. Double check torque on the two strut bolts - you actually want the torque wrench on the nut, not on the bolt. I've made this mistake and they came loose due to lack of torque, I like to overtorque by ~5 ft-lbs here. |
| ***NEED SOME HELP IN THE NEXT FEW HOURS IF POSSIBLE??*** | NorCalGirl | Northern California | 1 | 01-21-2015 06:39 PM |
| Help installing coilovers | eSOLOR | Northern California | 13 | 12-16-2014 01:51 AM |
| Installing Coilovers in Las Vegas | bobsacamenoh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 09-09-2014 10:14 PM |
| Crap lights on my dash after installing coilovers. | Eelusive | BRZ First-Gen (2012+) — General Topics | 43 | 02-12-2014 02:08 PM |
| 32 Hours 7 Minutes | Wes B. | Other Vehicles & General Automotive Discussions | 11 | 12-26-2012 10:10 AM |
