Drives: 2013 10 Series FRS
Front brake rotors swapped to rear
has anyone ever bought a big brake kit for their front brakes and then just swapped the oem front brakes to the rear brakes? if so, what exactly would you need to do? swap out the calipers and the rotors, or just swap rotors? (assuming if you swap the calipers as well the brake pads and mountings will go with it). thank you
#2 |
You should look into how your parking brake works, and then delete this thread.
#3 |
Not a troll
Wat
#4 |
One way to find out!
#5 |
Now w/ over 400 womprats!
Drives: BRZ LZR
As @Tokay444 said, this is not possible due to the rear brakes having drums incorporated into them for the parking brake. Additionally, most BBKs are made with brake bias in mind, and putting a different setup on the rear that is not paired to the fronts could potentially have poor results.
- The Ancient BRZ Sacrament by Zaku |
#6 | |
| FS: OEM FR-S/BRZ front and rear brake rotors (made in Japan) | DR 86 | Canada Classifieds | 3 | 10-11-2015 04:50 PM |
| Stock front brake rotors | JS + BRZ | Want-To-Buy Requests | 8 | 09-28-2015 03:58 PM |
| Removing rear brake rotors? | Kuzuri | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-18-2015 10:08 PM |
| Password:JDM Front/Rear Performance Brake Rotors 13+ Subaru BRZ | password:jdm | Brakes, Suspension, Chassis | 63 | 09-22-2014 04:32 PM |
| StopTech Slotted Brake Rotors (Front/Rear) for BRZ/FRS at Redline360 | Redline360 | Brakes, Suspension, Chassis | 0 | 07-13-2012 11:58 AM |
