Old 04-18-2014, 04:27 PM   #1
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
How to remove SCION silk screen logo from Headunit
For those wondering how to remove the Scion logo from your headunit trim ring....
DIY at Own Risk
Acetone will remove this silk screened logo from the black plastic without discoloring the plastic. Takes a couple minutes wetting and rubbing, but it comes off relatively easily.
* Some members have reported that acetone has made the h/u trim ring appear faded, or scratched looking.
1 - Please make sure to thin down acetone with water if you have pure acetone - nail polish remover contains acetone but is generally too diluted already.
2 - make sure to use a cotton ball / q-tip / microfiber cloth / anything non abrasive to rub the silk screened logo off as to avoid marring the surface of the trim ring itself.
This has really complimented my Toyota rebadge, now to eliminate the Scion splash screen from the headunit boot up sequence..
Others are encouraged to post pics and feedback.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 04-21-2014, 11:42 AM   #2
mx5 2nr
Drives: FRS/NA1/'12 Mustang/'97 4Runner
Thanks for the tip! Does anyone know if this will work on the 2013 BeSpoke headunit as well? It appears to have a gloss black finish.
'90 Miata - weekends
'13 FRS - weekdays
'97 4-Runner - grunt work
'12 Mustang - wife's
mx5 2nr is offline   Reply With Quote
Old 04-21-2014, 12:01 PM   #3
Danklvr
Danklvr's Avatar
this will work with all types of silk screened ink on plastic, just dont "scrub" too hard or you will scratch the plastic with whatever your using to "rub" the ink off. I used a microfiber cloth and didn't get any scratching. The plastic is hard, but i wouldn't use any abrasive or rough towels or anything as a matter of precaution.
I'm sure a q-tip or cotton ball or the like would be fine.
Old 04-21-2014, 12:17 PM   #4
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Make sure you thoroughly clean all the acetone residue too.
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 04-21-2014, 10:14 PM   #5
ST22
ST22's Avatar
Drives: 2014 6MT Asphalt FRS
Well, I know what I'm doing tomorrow. Thanks man.
ST22 is offline   Reply With Quote
Old 04-21-2014, 10:51 PM   #6
Choob
Choob's Avatar
Drives: 2013 Firestorm MT, 2004 Celica Gt
Perfect!!! Now how do we get rid of that horrible scion startup screen, there has to be a way!
Choob is offline   Reply With Quote
Old 04-21-2014, 10:58 PM   #7
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Do you think it will work on the factory 13' FRS base radio/headunit?
AVodka14 is offline   Reply With Quote
Old 04-21-2014, 11:21 PM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
X2
Old 04-21-2014, 11:50 PM   #9
Danklvr
Danklvr's Avatar
im sure someone can figure out how to flash the toyota entune/ display audio firmware onto the h/u or nav module.... someone not me...
Old 04-21-2014, 11:55 PM   #10
Choob
Choob's Avatar
There has to be a way because the corolla has the same head unit
Old 04-22-2014, 12:01 AM   #11
Zen86
Run, Reach, Fly
Zen86's Avatar
Drives: Monogram Firestorm
I tried to use acetone on my '13 frs and it left a pretty bad haze. Maybe I put too much pressure. Might try again with my '14.
Also +1 for changing the start up screen
Zen86 is offline   Reply With Quote
Old 04-22-2014, 01:56 AM   #12
Danklvr
Danklvr's Avatar
I used very light / no pressure and a non abrasive microfiber cloth.
Also be sure to clean residue afterwards thoroughly..
Is the haze scratching, or is it residue from the logo smeared around? Maybe try thinning the acetone slightly if your using 100% and if the plastic looks to be fading from the solvent, not from scratching.
Old 04-22-2014, 02:22 AM   #13
Zen86
Run, Reach, Fly
Zen86's Avatar
I don't have the car no more but I think the acetone was actually eating the plastic. Might be cause I used too much force. Yea I was using 100%. I'll try to thin it this time. Thanks
Old 04-22-2014, 03:53 PM   #14
SlowGT
Drives: 2013 FRS
Nice!! I did this and it looks 100X better! Thank you.
SlowGT is offline   Reply With Quote
head unit, logo, rebadge, scion, stereo
headunit splash screen. encity5 Electronics | Audio | NAV | Infotainment 21 08-11-2017 03:00 PM
Remove logo from FR-S OEM all-weather floormats? nalc Cosmetic Modification (Interior/Exterior/Lighting) 4 11-11-2013 05:11 PM
GT86 logo centered (replaced Scion logo) jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 7 06-10-2013 10:13 PM
How to remove sync'd phones from headunit? ShoNUFF Electronics | Audio | NAV | Infotainment 3 01-09-2013 05:54 AM
