Old 09-30-2016, 03:06 AM   #1
cjdriiiiift
cjdriiiiift's Avatar
Drives: Ultramarine FR-S 6MT
transmission done?
two weeks ago, my transmission wouldnt go into reverse, first, or second. 3,4,5,6 gears would work, but in those gears, the shifter would be loose and wobbly. it could move 6 inches in any direction and still stay in gear. i drove to my mechanics shop like this, starting from stop in 3rd. when i get there, surprise surprise, the tranny is back to normal. ok so here i am two weeks later. and the tranny has done this again and seems to be stuck this way. i have googled, forum searched etc etc. cant find an answer.
my mech says the linkage is A-ok
cjdriiiiift is offline   Reply With Quote
Old 09-30-2016, 03:15 AM   #2
When were you planning on mentioning your trd short shift kit?
Old 09-30-2016, 09:40 AM   #3
cjdriiiiift
No short shift kit. All stock transmission.
Old 09-30-2016, 11:34 AM   #4
shellslinger
Drives: Whiteout FRS
Any mods to your vehicle?
shellslinger is offline   Reply With Quote
Old 09-30-2016, 12:18 PM   #5
cjdriiiiift
Header tune springs and wheels
Old 09-30-2016, 01:26 PM   #6
I'll guess the shifter gate plate has come lose or the linkage has just become unglued.
I reckon it's time for someone to open up the top and take a look see at the innards of the shifter.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
cjdriiiiift (09-30-2016), krayzie (09-30-2016), Ultramaroon (09-30-2016)
Old 09-30-2016, 02:20 PM   #7
swarb
Did your mech even inspect the shifter? Did you see him physically take out the shift boot etc to take a look? Many mechanics are too lazy and won't touch the interior or won't try to fix something they know nothing about, like transmissions.
The Following User Says Thank You to swarb For This Useful Post:
Old 09-30-2016, 02:47 PM   #8
Wow! I was absolutely sure that would be the issue. I'm still thinking something is up with the linkage, though.
Old 09-30-2016, 03:20 PM   #9
All the symptoms of a linkage issue. May even be a really simple fix! I call BS on the mechanic.
Old 09-30-2016, 05:05 PM   #10
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
The Subaru service manual will tell you how to gap the reverse lockout plate properly. You would need a feeler gauge from the local hardware store.
Once you remove the shifter boot you should be able to see it. Might need to remove the center console trim as well. The lockout plate needs some grease as well.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Sti transmission Reaper Engine, Exhaust, Transmission 3 04-05-2014 07:23 PM
Transmission frosty86 Issues | Warranty | Recalls / TSB 7 05-16-2013 03:15 PM
Transmission? Pplater AUSTRALIA 1 06-05-2012 08:17 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 01:48 PM
