Is not fast.
Drives: 2014 Whiteout M/T
Odd Cleaning Issue
So, bit of an oddball situation. I was recently testing some fancy new LED switchbacks in my turn signals, and one of them decided to not be one piece anymore.
![]() Current theory is that something in the LED's circuit board got rattled too hard and shorted. It continued to overheat until it must have caught fire a little bit and melted at the base. It blew two fuses on the way out, tail-turn and hazard-blinker. It even charred the socket quite a bit so I had to pick up a new one. I've got a new bulb in, another LED (I know, right?) but these have more of a proven track record so fingers crossed. Anyway, my main problem now is that the turn signal housing/lens has some charring and burnt glue residue in it now. I guess you could say I have naturally smoked turns now. ![]() I managed to clean up a bit of the residue with some rubbing alcohol and a toothbrush, but it's still pretty clear that a party went on in there. I'd really rather not have to remove my front bumper, bake open the lens (I think it's been cooked enough), and clean it that way. Anyone have any ideas to clean it out a little better? I was thinking maybe a wire brush with some goo gone.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
| The Following User Says Thank You to Manic For This Useful Post: | continuecrushing (09-10-2016) |
#2 |
did you somehow manage to get the old bulb out of that housing?
#3 |
Is not fast.
I'll take some real nice studio box photos of the charco- ahem, components. @continuecrushing and I managed to fish out the separated half of the bulb with one of these dealies:
![]() Not gonna lie, if not for the fact that it damaged my car, it's mighty impressive that this LED managed to get hot enough to not just melt but actually catch fire. Then again, I didn't witness the fire, so maybe it just smoked a lot. They were pretty cool while they worked though:
#4 |
Sarcastic SOB
Perhaps if you can try blowing some compressed air inside. On second thought,the best stuff for washing clear plastic is Scrubbing Bubbles. I use it to clean the ramps on all my pinball machines. Then you will need the toothbrush and compressed air shot.
#5 |
Is not fast.
I'll give that a shot!
#6 |
Drives: FRS
TRY
Methyl Hydrate - used as gas line antifreeze. Its used to remove water stains in car lights.
Make sure you get it with no other additives.
| The Following User Says Thank You to RFB For This Useful Post: | Manic (09-10-2016) |
#7 |
Drives: 2013 Firestorm FRS
also, for search reference:
When the two fuses blew, it replicated symptoms of a blown BIU. We were freaking out for a short while until we found the other fuse that was blown. |
| The Following User Says Thank You to continuecrushing For This Useful Post: | Manic (09-12-2016) |
#8 |
Is not fast.
Never heard of that before. I'll check it out tomorrow after a much needed car wash.
#9 | |
Automotive Enthusiast
Drives: Zenki 86
| The Following User Says Thank You to D5teph For This Useful Post: | Manic (09-12-2016) |
#10 | |
Is not fast.
I tried the Methyl Hydrate/Methanol/Wood Alcohol/something-the-home-depot-guy-didn't-want-to-help-me-find-because-he-probably-thought-I-was-making-drugs-or-something, and it actually helped a bit. There's still some residue on the lens portion itself, might have to spray again and get one of those wire brushes with sponges on the end to reach. Nearly got my finger stuck in housing trying to use shop paper towels to scrub off the staining.
#11 |
Is not fast.
After great panic, we found that the "TAIL" (tail lights, turn signals, parking lights) fuse under the steering column and the "HAZ" (hazard lights, blinkers) fuse in the engine bay were the culprits. Luckily there were spares so I didn't have to drive at night in stealth mode.
| Spring Cleaning | C130NAV | Engine, Exhaust, Bolt-Ons | 24 | 08-02-2014 12:26 AM |
| Cleaning around and behind 3rd brake? | Wankel Rex | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 01-13-2013 05:29 PM |
| Self-cleaning cars on the way! | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 07-25-2012 06:58 AM |
