Old 06-02-2019, 11:04 PM   #1
chi86
Drives: Asphalt Gray Base FR-S 6mt
Unhappy OEM head unit no sound HELP
I was trying to install a camera using the Autoharnesshouse kit. Did not disconnect battery because I'm a dummy. Went to connect one the 10-pin harness to the back and saw a spark. Got everything put back together, OEM head unit turns on but no signal to speakers. The screen works, it can read from USB, etc., just no sound. I've tried disconnecting the battery for a while, no effect.
The clock and dome light still work, so it's not a fuse (at least not the radio fuse). What else should I check? Or is the head unit fried?
chi86 is offline   Reply With Quote
Old 06-03-2019, 12:08 AM   #2
chi86
Update: checked amp and head unit fuse just to be sure, both look fine. Upon researching this further, I learned that I had probably spliced the camera's ground into right front speaker (-) (pin 5) instead of pin 7, the ground wire. I will adjust tomorrow and update the thread.
Old 06-03-2019, 12:09 AM   #3
chi86
I hope this works, because I might kill two birds with one stone: have my head unit working properly again and have a functioning rear view camera.
Either way, I have an Alpine ILX-007 standing by for install, just really hoping to get this speaker issue fixed first to be sure that the Alpine works too.
Old 06-03-2019, 11:43 AM   #4
chi86
Redid the camera ground wire today from pin 5 of the 10-pin harness to pin 7. Audio is back! Camera still doesn't work, but I'm done trying to get it to work at this point. I will try again when I'm installing that Alpine, maybe I'll have better luck then.
For Sale: Stock BeSpoke Premium Audio head unit with NAV unit Glok24 Audio/Visual, Electronics, Infotainment, NAV 13 07-22-2018 01:34 AM
Looking for help adding sub and amp to existing 2016 FRS sound system and head unit Sonicp9 Electronics | Audio | NAV | Infotainment 2 02-27-2016 11:24 PM
BRZ Nav Head Unit Sojhinn Audio/Visual, Electronics, Infotainment, NAV 16 11-03-2013 07:02 PM
head unit swap speakers sound flat and muffled iketiak Electronics | Audio | NAV | Infotainment 5 04-20-2013 09:48 AM
looking for a head unit for Fr-s like the Brz. enjoi23 Electronics | Audio | NAV | Infotainment 5 08-08-2012 03:51 PM
