Old 07-24-2013, 08:38 AM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
AVO Turbo Kit Owners Topic
I've been meaning to do one of these ever since it was made for other kits. I was waiting to have Dyno numbers before doing it, but I got them and forgot to create the thread. Well, here it is. I believe its a good way to help out others and get ideas on what works with your build all in one thread.
Whomever wants to know what setup works, or what custom modifications every car has, please go to the build thread as usually the OP has a summary of what each car is running.
Members list:
1) @protpibe
2) @nix Nix's Build Thread
3) @JD86 JD's Build Thread
4) @BRZranger Turbo Install on A/T BRZ
5) @gdrider77 Grider's Build Thread
6) @GC GTS Aero Kit GC GTS Build Thread
7) @deucethemoose
8) @DAMotorsports DAM Motorsports Build Thread
9) @killerkid08
10) @Pitman Pitman's Build Thread
11) @InvalidJohnny5 Johnny's Build Thread
12) @Lammie
13) @nataku Nataku's Build Thread
14) @Pete156
15) @spitfire481 Spitfire's Build Thread
16) @tonyfrs86
17) @brz2013
18) @DesertFrs
19) @andrewFT86 Andrew's Build
20) @Touge_ninja Ninja's Build
21) @qtwre
22) @SkAsphalt
23) @Art_Mighty
Please reply to the thread and let me know if you are an AVO kit owner to add you to the list and let me know if you have a build thread.
Useful links:
Turbo Installation Prep Tips
Fuel Pump Installation Tips
Subaru Metal Gaskets for Manifold (Turbo Legacy Gaskets) part number 14038AA000
Update from AVO regarding stage 3 turbo kit.
Originally Posted by AVOturboworld View Post
Stage 3 testing on the AVO Turboworld Japan BRZ
We've been hard at work here at AVO on a variety of projects, with possibly the biggest one right now being the Stage 3 upgrades for the AVO BRZ/FR-S turbocharger kit. Our Stage 1 turbocharger kit has been incredibly popular worldwide, and has made a lot of people very happy by bumping the power up dramatically, from 165whp to 260+whp. Yet some people want more, much more, and we've listened to their requests.
It would have been easy enough to just up the boost and get a few glory runs on a dyno, but we are far more committed to our customers long-term enjoyment than that. We wanted Stage 3 to be as reliable as possible, with all the high-quality engineering and attention to detail that has been a trademark of AVO for the last 40+ years.
To this end, we spent a considerable amount of time and testing on our fuel pump upgrade, as the car was already starting to reach the limits of the pump at 300whp, and we were planning to go much further than that. After much time and effort, we have now got a full bolt in, no fitment compromise fuel pump that does not require any re-wiring or dremelling. It clips right in to the assembly, and doesn't require you to have the fuel filter mashed up against the bottom of the pump housing. The standard wiring harness will clip right into it as well, and it doesn't require additional O-rings to seal up.
Matched up with that is our upgraded Port Injectors. These were also designed to fit to the BRZ/FR-S, with the longer "neck" on it so that they reach down into the intake system and spray properly, unlike some other "short" designs that merely let the gas puddle down. Put these together with the fuel pump, and we now had the fueling to push the engine further.
But why so much extra fuel? Because we upgraded the turbocharger as well! The Stage 3 turbocharger utilizes a new billet compressor wheel with a more efficient design. While the overall size of the turbocharger hasn't changed, the flow has improved dramatically enabling us to push it harder at higher boost levels. This allows up to bump up the peak horsepower available while keeping the impeccable low-end torque that makes this turbo kit such a pleasure to drive.
The final piece of the power puzzle is the complete 3" exhaust system that will come with this kit. We don't mean just from the cat-back, no, this exhaust is 3" from the turbo charger exhaust housing back. The turbo discharge pipe and crossover pipe have been re-designed to provide maximum flow from the turbo all the way back.
As part of the testing we recently put the Stage 3 kit through it's paces at the RevSpeed Super Battle Time Attack at Tsukuba Circuit. It went very well, with the car going roughly 1.5 seconds faster around the circuit on the exact same tires as earlier in the year. Power through the corners was very well controlled, and it was a rocketship exiting the corners and on the straights.
Immediately after the event we put the car on the dyno to see how it was doing at the race settings. Power was quite impressive, with 373whp on tap at 6400rpm, and a peak of 318ft/lbs of torque at 4800rpm. Even more exciting is how it was doing 290ft/lbs of torque from 3300rpm. This is a quick-responding turbo!
We are still undergoing testing, but expect to see this available soon from AVO!
The Following 18 Users Say Thank You to Sportsguy83 For This Useful Post:
andrewFT86 (07-24-2013), ChilOut (07-29-2014), CxG (06-25-2016), DAMotorsports (07-25-2013), DesertFrs (10-04-2013), Draco_PR23 (07-24-2013), Freedom (03-10-2015), FRSBRZGT86FAN (11-21-2014), JD86 (07-24-2013), Jrdad (02-23-2014), lukmanaryadi (05-21-2014), M1K3 (07-24-2013), MFB (11-07-2013), nix (07-24-2013), pcuerpo (04-20-2016), Pete156 (07-24-2013), Pitman (07-24-2013), SkAsphalt (02-04-2014)
Old 07-24-2013, 12:13 PM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
mine has been bought, just waiting for this batch to be finished/shipped. cant wait
The Following User Says Thank You to spitfire481 For This Useful Post:
Sportsguy83 (07-24-2013)
Old 07-24-2013, 12:16 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Damn it @Sportsguy83. Now you are going to make me have to make one.
ftc~brz (08-21-2013)
Old 07-24-2013, 12:17 PM   #4
Sportsguy83
Drives: Limited BRZ
Your move!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 07-24-2013, 12:29 PM   #5
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Ditto.
FrX is offline   Reply With Quote
Old 07-24-2013, 02:09 PM   #6
Sportsguy83
Drives: Limited BRZ
So no other current AVO kits?? @vubaru was going to part out, also saw @driver01 but apparently he also sold car, or was looking for warranty since all his thread with info now say DELETE....
Old 07-24-2013, 02:10 PM   #7
Sportsguy83
Drives: Limited BRZ
Originally Posted by FrX View Post
Ditto.
As soon as you guys install let me know!
Old 07-24-2013, 02:10 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Your move!!
Checkmate.
Old 07-24-2013, 02:19 PM   #9
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
As you know, I'm waiting on my kit too. I will also let you know once I install it.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Old 07-24-2013, 03:00 PM   #10
spitfire481
Drives: 2JZ FRS
I'm doing an all at once kind of build thread once the kit is in. Figured its better than updating a thread for every new part I buy. This kit pretty much finishes my car for a while
ftc~brz (07-24-2013)
Old 07-24-2013, 03:01 PM   #11
Sportsguy83
Drives: Limited BRZ
I did the same. I'm here for any questions or concerns regarding install.
Old 07-24-2013, 03:29 PM   #12
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Really looking forward to this thread's development. I have my heart set on the Avo as soon as I free up some income and work out the warranty kinks.
DoomsdayJesus is offline   Reply With Quote
Old 07-24-2013, 03:45 PM   #13
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
I will be a proud AVO Kit Owner by the middle of next week. My car is going in on Friday for the kit to be fitted
Pitman is offline   Reply With Quote
The Following User Says Thank You to Pitman For This Useful Post:
Old 07-24-2013, 03:52 PM   #14
Sportsguy83
Drives: Limited BRZ
I can't believe we are mid-2013 and there are such few already installed owners of the kit.
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
