Old 06-28-2016, 07:42 PM   #1
pbirmingham1988
pbirmingham1988's Avatar
Drives: 2013 Scion FR-S Hot Lava - BBW
Spc control arms and negative rear camber question
So I installed the spc lower control arms, but it's obvious that the right side tire has more camber than the left. I just got a wheel alignment done and the guy said he went as far as he could to match it up as best he could. I asked for-2 camber on both sides, but the left lower control arm doesn't seem to allow that negative camber on my car for some reason.
Is it possible that it was a bad install or if the lower control arm is warped/bent/bad? I'm not a mechanic and I'm clueless to this stuff but I feel the car still moving to the right after the wheel alignment. Any suggestions on what I can do?
pbirmingham1988 is offline   Reply With Quote
Old 06-28-2016, 08:01 PM   #2
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
sounds like a bad job to me. alignments are done by lasers in most shops, possibility of it being warped is minimal.
slyphen is offline   Reply With Quote
Old 06-28-2016, 08:01 PM   #3
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Right from the factory, most peoples cars have slightly different alignment right and left. I've seen some people show slips with 0 camber on one side and -0.8 on the other which is a pretty huge difference but would be considered "in spec." Besides the fact that each side might be slightly different, there are a wide variety of reasons they may not be able to get the same amount of camber on each side. Some of it can be a difference in mounting points and structure between each side, some of it can be minor differences between the arms and finally, a lazy/poor alignment tech could also come into play.
What are the stats they ended up with?
Lynxis is offline   Reply With Quote
Old 06-28-2016, 08:04 PM   #4
gramicci101
Off Topic
The SPC arm looks very similar to the OEM arm, just with slots cut for adjustment. Maybe they got the arms mixed up and put the OEM arm back on that side?
I got -2 just from lowering springs, no LCA at all. So something is definitely wrong there.
Old 06-28-2016, 08:46 PM   #5
pbirmingham1988
He used a legit wheel alignment machine, and I watched him do it. I think there's something wrong with the lca
Old 06-28-2016, 08:48 PM   #6
pbirmingham1988
I didn't get a picture of the stats, but he said the control arm won't allow him to put anymore camber. I watched him do it
Old 06-28-2016, 08:53 PM   #7
pbirmingham1988
Possibly. Let me double check when I get home but is there a possibility that the guy who installed the lower control arms did it incorrectly?
Old 06-28-2016, 10:02 PM   #8
gramicci101
Off Topic
There's only so many ways it can go on. If it's connected to the hub, the shock, the swaybar endlink, and the chassis, it's on there correctly.
Old 06-28-2016, 10:40 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
What were your before and after specs?
Old 06-29-2016, 12:03 AM   #10
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
if you don't know how it works then you will have issues doesn't mean the machine is bad, or they butchered something (unless they crushed that tab) just gotta know how it works.
the way you adjust those is with that bolt-washer/cam that gets pushed against the slit on the arm (DO NOT CRUSH THAT). you turn it, because it is eccentric it will gain and drop camber-while doing that you want to adjust toe too to level it out and tighten it all down.
referring to this bolt/washer against that tab to its left:
you want to slightly toe in the rear. like .08. you don't really need -2 camber in the rear unless you have rubbing issues. i'd go for like 1.7-1.8. in the front aim for about -2 with toe out a bit.
to help understand what is happening post your latest specs on here please.
Jive Turkey is offline   Reply With Quote
Old 06-29-2016, 12:52 AM   #11
pbirmingham1988
I installed tein street basis coilovers n dropped it a bit but I only installed these lower control arms like a week later n everything was stock. I never messed with toe or camber or anything before this.
Old 06-29-2016, 12:58 AM   #12
pbirmingham1988
I only need the camber because of tire rubbing after i dropped the car. I'll go to the guy who installed this tomorrow to see what's going on. Cuz even when I'm driving I feel like I'm slipping from the rear and I think it's caused by the uneven camber in the back. I called up spc too to see their insight on the matter but the techs weren't there, so i have to call back tomorrow. Thanks for the explanation on how it works btw. I'll talk to my guy tomorrow cuz this ain't right.
Old 06-29-2016, 01:08 AM   #13
finch1750
finch1750's Avatar
the printout from the shop will show what it was when it came in and when it left. Did you get one?
Old 06-29-2016, 02:12 AM   #14
pbirmingham1988
Nah they didn't give me anything
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 03:08 PM
SOLD: Rear Upper Control Arms WITH Whiteline Camber Bolt Kit KVDB31 Brakes, Suspension, Chassis 16 07-02-2016 11:14 AM
rear camber adjuster bolts or lower control arms? mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 06-30-2015 09:34 AM
rear camber adjuster bolts or lower control arms needed? Raven23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-31-2013 02:30 AM
SPC rear lower control arms, Fix your camber! JoeBoxer Brakes, Suspension, Chassis 12 03-31-2013 08:02 PM
