CANADA Canada
Old 07-11-2012, 11:01 AM   #1
drei
drei's Avatar
Drives: 2013 Scion FR-S Asphalt
FR-S headunit replacement
Has anyone done this yet?
I stopped by Futureshop last night and they had a bunch on sale.. including the Pioneer AVIC-X930BT for $499 (its a GPS unit).
Now I believe this is almost the exact same one that is in the BRZ in Canada (maybe they have the 940), but would it be basically plug and play or would it still have to be rewired
drei is offline   Reply With Quote
Old 07-11-2012, 11:07 AM   #2
solution
solution's Avatar
Drives: Scion FRS
You need to get a Wiring kit and mounting bracket. You will also need an antenna adapter.
Take a look in the Audio section of the forum you will see a DIY guide and model #'s of the parts you will need.
solution is offline   Reply With Quote
Old 07-11-2012, 11:38 AM   #3
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
You need those spacer things on each side
quik1987 is offline   Reply With Quote
Old 07-11-2012, 11:43 AM   #4
drei
drei's Avatar
thanks for the replies!
would i be able to rewire to the factory mic? or would I have to use the new pioneer one?
also for brz owners.. how is that headunit? would you recommend?
Old 07-11-2012, 12:24 PM   #5
pastuch
pastuch's Avatar
That's almost identical to the one we have in our BRZs and it's quite good. I'm very happy with it. Just enough physical buttons. The resistive touch screen is a little frustrating sometimes but they ALL are.
pastuch is offline   Reply With Quote
Old 07-11-2012, 01:35 PM   #6
Aznek
Drives: 2013 White Scion FRS
AppRadio 2 has a capacitive touch screen.
Aznek is offline   Reply With Quote
Old 07-11-2012, 05:03 PM   #7
DarthNads
Drives: 2003 Mazda Protege 5 limited
Just checked it out on the Pioneer website, I want one now!
DarthNads is offline   Reply With Quote
Old 07-11-2012, 05:08 PM   #8
drei
drei's Avatar
check it out at FS as well..
3 things turned me off of it..
1. lack of cd/dvd drive
2. i have an android and apparently i then require some sort of addon for it which costs $250
3. the touch screen sucks
Aftermarket third brake light replacement? mechaghost Cosmetic Modification (Interior/Exterior/Lighting) 18 03-25-2014 12:33 PM
Toyota Emblem replacement jarviz Cosmetic Modification (Interior/Exterior/Lighting) 3 07-26-2012 12:12 PM
OE Replacement Dampers Sccabrz192 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-08-2012 12:52 PM
Tail light replacement? alexm Cosmetic Modification (Interior/Exterior/Lighting) 5 06-05-2012 05:38 PM
Stock FRS Headunit/Speaker preformance jflogerzi Electronics | Audio | NAV | Infotainment 8 06-03-2012 02:03 AM
