Old 12-05-2018, 03:01 PM   #1
djezlee
Drives: 2017 BRZ Limited
Greddy Profec Boost Controller
Is anyone running the Profec Boost Controller? I am looking for a review or recommendation before I commit to buying one. http://www.greddy.com/products/electronics/profec/
djezlee is offline   Reply With Quote
Old 12-05-2018, 07:43 PM   #2
Trust86
Drives: 2016 Halo FRS
I ran one on my S15 in Japan, no complaints!
Trust86 is offline   Reply With Quote
Old 12-13-2018, 08:26 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Had the profec B spec on a 3000gt. Was a great boost controller.
Old 12-21-2018, 03:21 PM   #4
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Depends if your tuner can tune with it. It doesn't have the inputs needed for plug and play to our cars. I only use my PROFEC for the Boost display now and run the Delicious tuning boost controller for tuning. .
Decimus is offline   Reply With Quote
Old 12-21-2018, 05:17 PM   #5
steve99
Drives: FT86
If your running ecutek tuning on 86\brz you dont need boost controller Just the boost solenoid\mac valve, all the control can be done in the standard ecu with the ecutek software. Eg boost per gear per rpm overboost control , boost reduction on knock and more, no need for external boost control electronics
Old 12-29-2018, 02:13 AM   #6
Eazy-V
I’ve been running it since June 2016 and it’s great!
I have my car EcuTek tuned with 3 modes on Profec:
1. Profec OFF = 8psi wastegate tuned from Shell 91-E73
2. Profec LOW BOOST = 12psi tuned from Shell 91-E73
3. Profec HIGH BOOST = 18psi tuned for E73
I sometimes dial down HIGH BOOST to 16psi
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 12-29-2018, 02:46 AM   #7
tomm.brz
Drives: brz 2017 hksv2
How do you connect the profec to the ecutek tune? I guess custom maps are in use in your case, but how do you give the input with the profec?
Old 12-29-2018, 06:16 AM   #8
Eazy-V
The Profec is technically independent of Ecutek, so basically I have the car tuned for Shell 91 up to 12psi and E73 up to 18psi where I use Profec to set the psi and fine tune gain and etc. Once it’s tuned I then have 3 presets on Profec.
I like Profec cause I can on the fly switch presets for more boost anytime. Like I can cruise with it off getting 8psi on E73 then press high and get 18psi on E73.
Just make sure you have a tuner who’s familiar with both EcuTek and Profec.
Old 12-29-2018, 06:44 AM   #9
djezlee
Pretty sure HRI will be doing an E tune for me. I don't know their experience with the Profec boost controller though
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
Kart boy short shifter, Perrin Crank Pulley, Greddy & Grimmspeed Boost Controller Cross Engine, Exhaust, Bolt-Ons 8 10-01-2014 01:42 AM
Greddy PRofec OLED NOTORIOUS.BRZ Forced Induction 16 11-25-2013 12:23 PM
Greddy New Profec Boost Controller Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 4 01-16-2013 06:12 PM
