Drives: 2013 Scion FRS 10 Series AT
Brake Sound
I've finally found a video that replicates what my brakes sound like. When I release them I hear a clunk. Anyone have this issue?
[ame="https://www.youtube.com/watch?v=IPk2Usz1sxs"]FRS Brake Noise - YouTube[/ame] And yes, it happens when it's not raining and the brakes are not moist. Thanks guys! |
#2 |
No, I haven't noticed my car doing that except maybe once, after the emergency brake has been released.
But if it did, I would suspect that my car had a brake caliper sticking. I'd pull off the wheels and check them out. Or, more likely in my case, run the car up to the local brake repair place and have them check them out ...... ![]() humfrz |
#3 |
[insert cool phrase here]
Drives: BRZ Premium
Sounds like worn brake shoes to me. Or some gunk up on the springs on the shoes.
Like humfrs said drop by any brake shop and have them take a look. Or if you are mechanically inclined, do it your self.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | humfrz (05-13-2016) |
#4 |
Does the sound happen only when it's damp or wet out?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#5 |
#6 |
Drives: 2015 BRZ Limited
My '15 brz makes the same noises.. not too sure whats up with that, i notice it mainly when I'm in a parking or at a light. No moisture/rain, im in SoCal but not super close to the beach, either, so salt water shouldn't be it. I'll see about running to a brake shop as soon as i can to see what's up.
#7 |
Let me know if you find a solution.
Sent from my SAMSUNG-SM-G935A using Tapatalk |
#8 |
The solution is to take them and have them checked.
#9 |
I understand that and I'm not able to get that done yet so being able to have someone that can before me let me know what they found would be nice.
#10 |
Brakes and steering are two things you wait to "get done" if you suspect there is something wrong. You bite the bullet and deal with them right away. Unless of course the car is parked and not being driven in which case you have all the time in the world to deal with it. His issue and yours may not be the same anyway.
| The Following User Says Thank You to Tcoat For This Useful Post: | nos145 (05-18-2016) |
#11 |
I know that. I'm unable to do anything with the vehicle right now.
| The Following User Says Thank You to euthqt For This Useful Post: | Tcoat (05-17-2016) |
#12 |
Well it is good to know you are not driving around for a couple of months with a potential braking issue.
| Drone (Worn Wheel Bearing SOund) Sound From Rear | qbzee007 | AFRICA | 8 | 11-14-2014 01:04 AM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
| Air/hiss sound when depressing brake petal | TM | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 06-10-2013 10:29 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| Puget sound Tint option that won't break the brake light | rice_classic | Northwest | 17 | 09-05-2012 07:22 PM |
