Drives: 20 GT86
KW V3 vs KW V3 CS & Camber Plates and End Links
Hi,
I'm currently planning my next upgrade suspension-wise but there are a few things that I still can't quite understand. 1- Is the KW V3 and the KW V3 Clubsport the same thing but the Clubsport includes camber plates? If no, what's the difference? If yes 2- The KW V3 and the KW V3 Clubsport are 1200€ apart, wouldn't be better to get the KW V3 and the RACESENG Camber plates? 3-I don't plan on slamming the car but I've read that End-Links are a good buy in terms of future proofing the car and being conservative longevity wise. Roads here are a bit crap and I already have a clunking noise on the FR with the stock suspension. Would the Whitelines KLC179 and KLC182 Anti-Roll bar links be any good? And, if it matters, everything suspension related will be installed, aligned and corner balanced by professionals. If it also matters, the car is daily driven, but sees a lot of spirited driving and occasional track days. Last edited by KiK; 06-08-2023 at 10:53 PM. Reason: Extra information |
#2 |
Drives: '13 FRS - STX
Unless you need the kw camber plates for road legal inspections, the raceseng camber plates are way better.
With modest lowering and kw struts the oem end links will be lowest maintenance. The white lines came loose on me. |
#3 |
The regular KW V3 are softer at 4 kg/mm front and 5 kg/mm rear.
KW V3 Clubsport are 6 kg/mm front and 7 kg/mm rear (with valving to match). I quite like the KW camber plates + rear mounts and would prefer them over Raceseng for a daily driver. They're quieter in my experience and the pillowball is sealed on the bottom side which is nice. The advantage of the Raceseng plates is a little extra caster. You might be able to get a little more camber out of them. They are good plates too. I'm not sure which camber plates have a lower stack height but my gut says it's the KW's (for more bump travel). But that's eyeballing it. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | MrSkubi (06-10-2023) |
#4 | ||
Drives: 20 GT86
I actually do need them for certification purposes (since I believe they are required for TUV compliance) however I wouldn't mind getting the stamp on and then swaping the camber plates provided that the benefit would overcome the cost and the effort. Do you know any other good adjustable end links other than the whitelines? Because I'm confident that mines are busted anyway and for the price the dealership will ask me for it it won't be much different from an aftermarket one. Quote:
Thanks! So there is an actual difference. I'm inclined to go with the V3 CS with the CS plate and call it a day. I don't plan on any crazy lowering nor any crazy camber. |
#5 |
Drives: Toyota 86
Just a note: actual V3’s can handle springs up to 7kg/mm on front and rear, of course you have to expect a narrower window for setups.
They cannot be revalved officially, while CS can. V3’s do have lifetime warranty while CS don’t. To me, regular v3’s with CS camber plates and rear lowering mounts are an awesome street/light track setup. |
#6 |
Drives: Toyota GT86
I use kW v3 cs with 7kg / 8kg springs and after 30,000km hard use they are still working perfect, the camber plates make no noise.
I am very very content with this suspension |
| The Following User Says Thank You to Ruben_86_ For This Useful Post: | Racecomp Engineering (06-11-2023) |
#7 |
Custom Switch Panels!
Drives: 2015 Subaru BRZ Series.Blue
One key difference is that if you have the normal V3s (like I did), and you're an idiot, and when calling to get them rebuilt after 80,000 miles, mention that you did autocross on them (like I did), then they kindly tell you that your warranty is void... because the regular V3 isn't meant to be used for competition (I'm dumb and didn't realize that at the time.)
Soooo that's how I wound up with RCE T2s, which are just tweaked V3 Clubsports, and handle so much better, without really being all that much more uncomfortable, lol.
| The Following User Says Thank You to RACECAR go brrr! For This Useful Post: | Racecomp Engineering (06-11-2023) |
#8 | |||
Drives: 20 GT86
Thanks, I will be going with the CS. Given my location dealing with warranty will be more painful that simply go to a local suspension shop that works with KW to repair / revalve them so that's not really a concern Quote:
Happy to know that, I will be going with the V3 CS, your replies gave me the confidence I needed. Quote:
Hi, crazy to see you replying on my thread, I've just installed your cubby hole switches a few days ago ![]() What I will be doing won't be exactly competition, however, thanks for the heads up! |
| The Following User Says Thank You to KiK For This Useful Post: | Ruben_86_ (06-12-2023) |
| Uneven camber with the camber plates maxed. | fr-steezz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 37 | 09-27-2022 10:15 AM |
| SOLD: Raceseng caster + camber - adjustable front camber plates | higrip | Brakes, Suspension, Chassis | 4 | 09-17-2019 02:43 PM |
| KW coilovers and camber (without camber plates) | wparsons | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 07-09-2018 09:53 PM |
| FS: HVT Non-raising camber plates & WL camber bolts | trippinbillies40 | Brakes, Suspension, Chassis | 1 | 05-16-2015 10:00 PM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-28-2013 12:38 AM |
