Old 04-26-2016, 05:39 PM   #1
vramsaran
Drives: BRZ Limited WR blue
grumbling noise from front end when turning
Took my car to the dealer today for scheduled oil change 13k miles . On the way home on the highway started to hear what sounds like a bad wheel bearings .
exiting the hwy in a right handed turn the growling grew louder and I could feel vibration through the steering wheel. .
Came home parked the car for about 20 mins toook it out again to see if I could reproduce the sound. Nothing . I drove for a few minutes and the sound returned .
Anyone else have this issue ? Only modifications to the car is new rotors, pads and 18 wheels and tires.
Currently running 245/35/18 all corners
vramsaran is offline   Reply With Quote
Old 04-26-2016, 06:21 PM   #2
MeisterR
MeisterR's Avatar
Drives: BNR32
base on what you said, few things I would check are
rotors, make sure they are not warp.
brake caliper, make sure piston aren't seized
wheel nut, make sure they are all tight.
Just a few quick thing to check.
Jerrick
MeisterR is offline   Reply With Quote
Old 04-26-2016, 06:21 PM   #3
shellslinger
Drives: Whiteout FRS
I'm just throwing this out there, but did you check to see if your wheels are torqued down? I honestly don't know what the issue is.
shellslinger is offline   Reply With Quote
Old 04-26-2016, 08:29 PM   #4
vramsaran
Wheels torqued, rotors are not warped , who knows what the problem is. Taking it to the dealer in the AM.
That engine crinkling noise after turning car off. lupindub Other Vehicles & General Automotive Discussions 4 12-13-2015 03:28 AM
Noise when turning steering wheel at low speed Slant Issues | Warranty | Recalls / TSB 7 11-06-2015 09:53 AM
Weird hmmming noise when turning?? congee Issues | Warranty | Recalls / TSB 8 09-08-2015 01:29 AM
Here's a weird one...noise hours after turning off sa1126 Issues | Warranty | Recalls / TSB 12 10-12-2012 04:15 PM
